ZME_WALLC-S scenes with razberry
bierisplezier
Post by bierisplezier »
I'm trying to get my razberry to execute scenes with my ZME_WALLC-S.
First some info about my setup:
- Groups are controlled with two buttons (parameter 1/2 = 1)
- Command to Control Group A, Parameter Number 11 = 1, work great with my dimmer.
- Command to Control Group B Parameter Number 12 = 8,
- I've checked associations for my wall controller and the razberry is associated with the life life group.
- Trap events from Remotes and Sensors module enabled, seeing 2 buttons (on / off), only available in the z-way-ha dashboard.
Some output when I push buttons for group B (in Central Scene to Gateway mode)
[2015-01-29 20:53:22.219] [D] [zway] RECEIVED: ( 01 29 00 04 00 08 23 98 81 72 48 E6 CC 47 DD F6 5A D2 C9 BC 56 04 23 DB B7 79 9A D6 0A 26 46 23 97 DE 50 3D 14 C2 B0 F1 7E 4E 83 )
[2015-01-29 20:53:22.221] [D] [zway] SENT ACK
[2015-01-29 20:53:22.222] [D] [zway] SETDATA devices.8.data.lastReceived = 0 (0x00000000)
[2015-01-29 20:53:22.223] [I] [zway] Node 8:0 CC Security: Received a secure message
[2015-01-29 20:53:22.225] [D] [zway] SETDATA devices.8.instances.0.commandClasses.152.data.firstPart = **********
[2015-01-29 20:53:22.226] [I] [zway] Node 8:0 CC Security: passing decrypted packet to application level: [ 8f 01 02 05 5b 03 54 02 02 05 5b 03 55 01 02 ]
[2015-01-29 20:53:22.228] [D] [zway] SETDATA devices.8.instances.0.commandClasses.91.data.sequence = **********
[2015-01-29 20:53:22.229] [D] [zway] SETDATA devices.1.instances.0.commandClasses.91.data.srcNodeId = 8 (0x00000008)
[2015-01-29 20:53:22.230] [D] [zway] SETDATA devices.1.instances.0.commandClasses.91.data.srcInstanceId = 0 (0x00000000)
[2015-01-29 20:53:22.232] [D] [zway] SETDATA devices.1.instances.0.commandClasses.91.data.keyAttribute = 2 (0x00000002)
[2015-01-29 20:53:22.233] [D] [zway] SETDATA devices.1.instances.0.commandClasses.91.data.currentScene = 2 (0x00000002)
[2015-01-29 20:53:22.234] [D] [zway] SETDATA devices.8.instances.0.commandClasses.91.data.keyAttribute = 2 (0x00000002)
[2015-01-29 20:53:22.236] [D] [zway] SETDATA devices.8.instances.0.commandClasses.91.data.currentScene = 2 (0x00000002)
[2015-01-29 20:53:22.236] [D] [zway] SETDATA devices.8.instances.0.commandClasses.91.data.sequence = **********
[2015-01-29 20:53:22.237] [D] [zway] SETDATA devices.1.instances.0.commandClasses.91.data.srcNodeId = 8 (0x00000008)
[2015-01-29 20:53:22.239] [D] [zway] SETDATA devices.1.instances.0.commandClasses.91.data.srcInstanceId = 0 (0x00000000)
[2015-01-29 20:53:22.239] [D] [zway] SETDATA devices.1.instances.0.commandClasses.91.data.keyAttribute = 1 (0x00000001)
[2015-01-29 20:53:22.240] [D] [zway] SETDATA devices.1.instances.0.commandClasses.91.data.currentScene = 2 (0x00000002)
[2015-01-29 20:53:22.241] [D] [zway] SETDATA devices.8.instances.0.commandClasses.91.data.keyAttribute = 1 (0x00000001)
[2015-01-29 20:53:22.242] [D] [zway] SETDATA devices.8.instances.0.commandClasses.91.data.currentScene = 2 (0x00000002)
[2015-01-29 20:53:23.585] [D] [zway] RECEIVED: ( 01 1F 00 04 00 08 19 98 81 95 BE C8 3A 00 42 06 D0 C7 B9 4D B8 E8 FB C1 DB C9 D5 68 52 96 91 23 21 )
[2015-01-29 20:53:23.586] [D] [zway] SENT ACK
[2015-01-29 20:53:23.587] [D] [zway] SETDATA devices.8.data.lastReceived = 0 (0x00000000)
[2015-01-29 20:53:23.588] [I] [zway] Node 8:0 CC Security: Received a secure message
[2015-01-29 20:53:23.589] [D] [zway] SETDATA devices.8.instances.0.commandClasses.152.data.firstPart = **********
[2015-01-29 20:53:23.590] [I] [zway] Node 8:0 CC Security: passing decrypted packet to application level: [ 5b 03 56 02 06 ]
[2015-01-29 20:53:23.590] [D] [zway] SETDATA devices.8.instances.0.commandClasses.91.data.sequence = **********
[2015-01-29 20:53:23.591] [D] [zway] SETDATA devices.1.instances.0.commandClasses.91.data.srcNodeId = 8 (0x00000008)
[2015-01-29 20:53:23.592] [D] [zway] SETDATA devices.1.instances.0.commandClasses.91.data.srcInstanceId = 0 (0x00000000)
[2015-01-29 20:53:23.593] [D] [zway] SETDATA devices.1.instances.0.commandClasses.91.data.keyAttribute = 2 (0x00000002)
[2015-01-29 20:53:23.593] [D] [zway] SETDATA devices.1.instances.0.commandClasses.91.data.currentScene = 6 (0x00000006)
[2015-01-29 20:53:23.594] [D] [zway] SETDATA devices.8.instances.0.commandClasses.91.data.keyAttribute = 2 (0x00000002)
[2015-01-29 20:53:23.595] [D] [zway] SETDATA devices.8.instances.0.commandClasses.91.data.currentScene = 6 (0x00000006)
I already searched the forum and saw some info about SwitchControl viewtopic.php?f=3419&t=21112. I enabled this module, after pushing add item in "List of remotes and switches to instantiate", I got 2 buttons. The buttons only show up in dashboard menu, if I go to preferences they don't exist under the widget menu.
Now I'm stuck how to "program" / assign scenes to the switchcontrol buttons. It is possible via the z-way-ha dashboard? For example pushing button 3, I want to open the door and switch on the light.
Can somebody point me in the right direction to get my wall controller to work and assign scenes to it?
noah
Re: ZME_WALLC-S scenes with razberry
Post by noah »
@bierisplezier:
did u get a solution with the problem? i have the same problem.
The logfiles show me that the controller get the scenes but i dont know who i can connect it with the devices i want.
rgroothuis
Post by rgroothuis »
Question on the ZME-WALLC-S controller, how does this device show up in your ZWave Expert GUI application? Mine doesn't allowed me to change the parameters. So I cannot configure that the controller needs to start scenes (parameter 11, 12, 13 and 14 to set to 4). Any suggestion/idea? See also my screen dumps.
Screen Shot 2015-04-09 at 23.19.51.png (99.08 KiB) Viewed 12417 times
Screen Shot 2015-04-09 at 23.19.34.png (46.2 KiB) Viewed 12417 times
Quax1507
Post by Quax1507 »
Sampe Problem here.
Is there a solution for this issue in meantime?
I am also using WALLC-S but branded as Devolo.
You need to select ZDDX (Select Device Description button) for this device. Choose Z-Wave.Me Wall Controller - they are same.
