Quad Core 1Gb RaspberryPi 2
http://www.theregister.co.uk/2015/02/02 ... i_model_2/
And it should run RaZberry with Z-Way unmodified:
https://www.youtube.com/watch?x-yt-cl=8 ... pv6w#t=364
UPDATE 20150204:Apparantly not true for Z-Way? :(
UPDATE 20150205:At a later time it seems to work :)
Re: Quad Core 1Gb RaspberryPi 2
Apparantly MS is going "embedded" on this device with Windows 10 for IoT
Interesting times ahead :mrgreen:
LAN-Opfer
Post by LAN-Opfer »
pz1 wrote:And it should run RaZberry with Z-Way unmodified:
...I think, an other image will be necessary with a adapted Linux-Kernel.
An interesting question is how high the power consumption will be
Uwe
Z-Way v2.0.1-rc18 on Raspberry Pi
Yes there is an updated Rasbian image. Mine is expected to arrive tomorrow or the day after.
LAN-Opfer wrote:An interesting question is how high the power consumption will be
I read somewhere that to save energy the clock would go down from 900 > 700 when idle. Don't know how they define idle..
dhanjel
Post by dhanjel »
Doesn't seem to be working on a clean raspberry install. :/ Ideas?
Setting up bind9-host (1:9.8.4.dfsg.P1-6+nmu2+deb7u3) ...
Setting up avahi-daemon (0.6.31-2) ...
[ ok ] Reloading system message bus config...done.
[ ok ] Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon.
Setting up libavahi-common-dev (0.6.31-2) ...
Setting up libdbus-1-dev (1.6.8-1+deb7u5) ...
Setting up libavahi-client-dev (0.6.31-2) ...
Setting up libavahi-compat-libdnssd-dev (0.6.31-2) ...
Setting up libnss-mdns (0.10-3.2) ...
First installation detected...
Checking NSS setup...
Making symlinks to libssl.so
Making symlinks to libcrypto.so
bash: line 92: $UPGRADING: ambiguous redirect
bash: line 93: $UPGRADING: ambiguous redirect
Getting Z-Way for Raspberry Pi and installing
--2015-02-04 15:47:33--  http://razberry.z-wave.me/z-way-server/z-way-server/z-way-server-RaspberryPiXTools-v2.0.0.tgz
Resolving razberry.z-wave.me (razberry.z-wave.me)... 46.20.244.36
Connecting to razberry.z-wave.me (razberry.z-wave.me)|46.20.244.36|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [text/html]
Saving to: `/tmp/z-way-server-RaspberryPiXTools-v2.0.0.tgz'
    [ <=>        ] 10,470      --.-K/s   in 0.09s
2015-02-04 15:47:33 (112 KB/s) - `/tmp/z-way-server-RaspberryPiXTools-v2.0.0.tgz' saved [10470]
bash: line 105: $UPGRADING: ambiguous redirect
bash: line 106: $UPGRADING: ambiguous redirect
tar (child): /tmp/z-way-server/z-way-server-RaspberryPiXTools-v2.0.0.tgz: Cannot open: No such file or directory
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error is not recoverable: exiting now
bash: line 113: $UPGRADING: ambiguous redirect
bash: line 114: $UPGRADING: ambiguous redirect
bash: line 178: $UPGRADING: ambiguous redirect
bash: line 179: $UPGRADING: ambiguous redirect
Downloading and extracting z-way-server failed
Exiting
Linux zwave 3.18.5-v7+ #225 SMP PREEMPT Fri Jan 30 18:53:55 GMT 2015 armv7l GNU/Linux
PeterClaydon
Post by PeterClaydon »
I also get the message ending as shown below. I've tried this with the latest Raspbian download on both a Pi 2 and on a Model B+. Both are the same. It looks like z-way-server is not compatible with the new Raspbian (with 3.18 kernel), rather than just the Pi 2.
Exiting
Shodan
Post by Shodan »
Same issue here. Tried re-install my pi B+ today from scratch and I can't install z-way server (It worked perfectly last week ...).
My kernel image is 3.18.5+ #744.
Tried to install with both "wget -q -O - razberry.z-wave.me/install/v2.0.1-rc12 | sudo bash" and "wget -q -O - razberry.z-wave.me/install | sudo bash" and end up with the same error.
Please help !
Just a little while ago, I managed to get v2.0.1-rc12 up and running on my new Quad Core Pi 2.
  • I dowloaded and copied the Rasbian image of 31-01-2015 to an SD card.
  • Powered up the Pi2, and made an ssh connection
  • Ran as suggested by the system raspi-config to set locales and time zone
  • wget -q -O - razberry.z-wave.me/install | sudo bash
  • rebooted
I could start the HA succesfully on my quadras.
As this is an experimental setup for testing with the UZB1 I got several errors of course, as I could not yet upgrade the dongle :(
pz1 wrote:As this is an experimental setup for testing with the UZB1 I got several errors of course, as I could not yet upgrade the dongle :(
In the meantime I understood that for UZB1 we have to wait a while longer for both an update of the new Expert User interface, and the launch of a license server.
