Can not load modules.json from userModules
I am in the process of adapting my experimental weather module for multilingual texts. I closely modeled it after the latest OpenWeather example. I do get the following error message in the log:
Notification: error (core): Can not load modules.json from userModules/Wunderground/module.json: SyntaxError: Unexpected token }
More log
[2015-03-04 14:22:39.589] [I] [core] Executing script: /*** Main Automation webserver module ***************************************** ...
[2015-03-04 14:22:39.591] [I] [core] Executing script: // Make this testable by pulling in underscore from the parent module ...
[2015-03-04 14:22:39.595] [I] [core] Executing script: /*** Main Automation storage module ***************************************** ...
[2015-03-04 14:22:39.608] [I] [core] --- Loading ZAutomation classes
[2015-03-04 14:22:39.684] [I] [core] Notification: error (core): Can not load modules.json from userModules/Wunderground/module.json: SyntaxError: Unexpected token }
[2015-03-04 14:22:39.710] [I] [core] SyntaxError: Unexpected token }
    at AutomationController.loadModuleFromFolder (automation/classes/AutomationController.js:225:29)
    at automation/classes/AutomationController.js:196:14
    at Array.forEach (native)
    at AutomationController.loadModules (automation/classes/AutomationController.js:195:37)
    at AutomationController.init (automation/classes/AutomationController.js:69:10)
    at automation/main.js:304:16
[2015-03-04 14:22:39.712] [I] [core] Starting ZWay Automation webserver
[2015-03-04 14:22:39.718] [I] [core] Loading modules...
[2015-03-04 14:22:39.724] [I] [core] Loading module SensorValueLogging from modules/SensorValueLogging
[2015-03-04 14:22:39.726] [I] [core] Executing script: /*** SensorValueLogging Z-Way Home Automation module ************************************* ...
[2015-03-04 14:22:39.729] [I] [core] Loading module OpenRemoteHelpers from modules/OpenRemoteHelpers
[2015-03-04 14:22:39.731] [I] [core] Executing script: /* RaZOR ...
I have looked at the code of both OpenWeather and my Wunderground side by side several times, but fail to spot the differences that would explain my problem. JS code passed online Lint test. So far I have only prepared the language/en.json file.
Wunderground.zip
(6.7 KiB) Downloaded 278 times
dolpheen
Re: Can not load modules.json from userModules
Post by dolpheen »
Bad comma at the end :)
"source": {
				"type": "select",
				"enum": ["JSON", "XML"],
				"required": true
P.S. For quick test I used
/JS/Run/fs.loadJSON('userModules/Wunderground/module.json')
Thanks for the quick reply, it works fine now. I do appreciate the mentioning of the quick test. Really helpful.
