back detector motion information
valdoison
Post by valdoison »
I have a feedback problem with motion detectors.
I did a lot of testing:
With detectors SP814, HSP02, SP103
With raspberry + Razberry + domoticz
With raspberry + Stick S2 + domoticz
With PC ubuntu 14.04 + Stick S2 + domoticz
With raspberry + Razberry + jeedom
and now with raspberry + Razberry + Zway
after a short time of operation, the detection of feedback is no longer done.
I can not find anything in the "JOB QUEUE".
There are several posts that speaks of this problem on this forum and also other software.
Is this a problem with ZWAVE?
Re: back detector motion information
valdoison wrote: and now with raspberry + Razberry + Zway
In this configuration using old Expert UI (http://raspberry_IP:8083/blueui/) can you produce here an image of the routing table? Menu -Network-Routing table. Please select expert mode in lower right corner.
That information gives a first impression of how strong your network is. A list of all your devices (battery and mains) would be useful too.
valdoison
Post by valdoison »
Attached is my routing table attachment.
Device 3: outlet Everspring AN157
Device 4: motion detector Everspring SP814
Network seems OK.
There is a very old post (2011) that says the device is broken. Don't know if that still is the case, or if a work-around has been found. Have no motion detectors yet, so I have to leave this to more experienced people.
