CustomUserCodeLoader
dschonac
Post by dschonac »
i am having a problem with the CustomUserCodeLoader.
I am using a javescript file to define z-wave binding with power-metering nodes, so that everytime a sensor value changes a script is executed.
It worked once, but now i get the following error
Can not init module CustomUserCodeLoader: Error: Uncaught ReferenceError: zway is not defined
Looking at the log file, i can see that my script is loaded right BEFORE the z-wave binding module is started, but it needs this module, otherwise it fails.
How can i ensure that z-wave binding is started before the CustomUserCodeLoader?
dschonac
Re: CustomUserCodeLoader
Post by dschonac »
This seems to be some kind of bug:
If i use
service z-way-server restart
i get the same message.
However, if i use
service z-way-server stop
and then
service z-way-server start
it works.
However, since i have to manually start and stop the service this is not really suited for autostart.
I read somewhere that i can put the path to the javascript file into the main.js in the automation folder, but i can't find it anymore. Maybe this would help? Can someone please tell me the syntax to execute my javascript via the main.js?
Since a long time I do experience the same with my UDP send module. Seemed to work better for a while with rc22, but now on rc23 I had to do reboot, start/stop and finally a reboot again before the module started sending messages again. In my case behaviour after restart/reboot is very irregular. Also the logs do not give a hint on what might be wrong (my CustomUserCodeLoader is the very first one loaded in HA)
