I've been using the RaZberry for a few months now with a few z-wave devices.
When the automation doesn't work as I expect I want to be able to see a log of events and actions. My previous X10 system had a very basic controller CM15 and this showed such a log.
However, I can't find anything like this on the RaZberry. The notification/warning on the HA UI almost has this with the Device Monitor module, but it's not really usable (Warning screen slow and hard to read and Device Monitor keeps on putting out duplicates)
The log file looked promising at first, but doesn't seem to contain all the information.
As an example, my outside front light was on this morning. From my automation setup this should only be possible if either an off event from a sensor at the front of the house wasn't produced or if the light was turned on other than by this sensor. I'd expect this to be easy to check, but it isn't.
Am I missing something obvious ...
Re: Am I missing something obvious ...
/var/log/z-way-server.log has the detail
By log I did mean /var/log/z-wave-server.log.
I've found sound information is hard to interpret and some is missing. For example:
So my example below of a sensor and a light is very hard to understand.
Looking at the log did reveal a problem though - stack trace below. I have one virtual device which is Daylight - wonder if this causes the error and if so why that's not part of the stack trace.
- Names used in setup aren't use in the log
Values are encoded
Actions taken by modules e.g. call scene, aren't logged (at least I don't think they are).
b
[2015-03-28 18:20:07.970] [I] [core] Error: Invalid argument
at Error (native)
at self.controller.devices.create.handler (automation/modules/ZWave/index.js:1395:12)
at _.extend.performCommand (automation/classes/VirtualDevice.js:243:37)
at automation/modules/SensorsPolling/index.js:54:22
at Array.forEach (native)
at AutomationController.onPoll (automation/modules/SensorsPolling/index.js:50:29)
at AutomationController.EventEmitter.emit (automation/lib/eventemitter2.js:317:33)
at automation/modules/Cron/index.js:133:42
at automation/modules/Cron/index.js:121:27
Have you tried to disable all not realy necessary modules (like sensorpolling) and than add them one to one to see where the problems start (slow response in your other topic)
I disabled a bunch of modules.
I notice the SunriseSunset module wasn't turning on lights - I'll see if the disabling makes a difference, although not obvious why it should. Seems to be due to me moving to newer RC.
The main thrust of the thread still stands - hard to see the main 'events' going on. In the case of the light I could find the id for the light and grep for that plus 'perform'. Not sure how I'd see that SunriseSunset has generated an event - don't think there's standard logging for 'source of event'.
I've also found a warning on the HA UI:
and in the log
I've downloaded new version of Daylight and that appears to have eliminated this error.
Type: core
Timestamp: 31/03/15-20:57
Message:
Can not instantiate module: Daylight: TypeError: Cannot read property 'get' of null
[I] [core]
Notification: error (core): Can not instantiate module: Daylight: TypeError: Cannot read property 'get' of null
at Daylight.update_state (automation/userModules/Daylight/index.js:158:19)
