I'm learning to operate the only two devices that I have now with the help of the guide "The RaZberry Smart Home Controller" (file RaZberryEndUserManual20.pdf) and I found the following problem in the interface UI Expert:
for both of the device (Fibaro Motion Sensor and Fibaro Double Switch) in the Configuration tab I find the advise "No configuration file"
Given that in the /opt/z-way-server/ZDDX I found many configuration files, for example the "540-010f-0800-1001-03-03-43-02-04.xml" (is the Motion Sensor file?), what should I do to fix it?
Claudio
