[HowTo] Authentication for your Razberry (using nginx)
dolpheen
Post by dolpheen »
The topic decribe how to set-up autentication for your Razberry. For example if you have several razberries in your local network and want to restrict access to them or if you want to securely access your razberry outside from your local network if you have static ip or dynamic DNS (as alternative for find.z-wave.me and until we have embedded authentication mechanism in z-way software).
The procedure was tested on Rasberry Pi 2 platform with 2.0.1-rc25 installed.
For installing you need access to command line of your razberry and be familiar with some linux editor ( I used Midnight Commander).
Step 1- Setting up of nginx server
Install it with the next commands from command line
sudo apt-get install nginx
Run it
sudo /etc/init.d/nginx start
From your browser go to IP address of your razberry (192.168.10.98 in my case)
If you see the following screen then congratulations! you have your personal server running on razberry!
In case of problems check the following link How to install nginx on Raspberry...
Step 2- Making nginx as reverse proxy for your Razberry
With your favorite editor edit the next file '/etc/nginx/sites-available/default'
Put the next lines in 'location /' section.
location / {
                proxy_set_header   X-Real-IP $remote_addr;
                proxy_set_header   Host $http_host;
                proxy_set_header   X-Forwarded-For $proxy_add_x_forwarded_for;
                proxy_pass         http://localhost:8083/;
In my editor it looks like that
Restart the nginx server
sudo /etc/init.d/nginx restart
Then go in your browser to IP of your razberry again.
You should see the Welcome screen of your Raspberry
Step 3- Provide access only for authenticated user
Install helper utility
sudo apt-get install apache2-utils
Create sample user and password for it more info...
sudo htpasswd -c /etc/nginx/.htpasswd superuser
Add the next lines in nginx configuration file '/etc/nginx/sites-available/default'
Add it in section 'location /' after proxy settings
auth_basic "Restricted";
auth_basic_user_file /etc/nginx/.htpasswd;
Then you should see request for your login and password to access the razberry.
But you still can access it on :8083 port, so lets block it.
iptables -A INPUT -p tcp -s localhost --dport 8083 -j ACCEPT
iptables -A INPUT -p tcp --dport 8083 -j DROP
Tha't s all! Now only user that knows password has access to your raZpberry! :ugeek:
***To revert changes to iptables run 'iptables -L --line-numbers' and check that there are 3 lines in INPUT section, then you can delete it with the next commands
iptables -D INPUT 1
iptables -D INPUT 1
iptables -D INPUT 1
Adding SSL - Step 1
Create certificate for your razberry more info...
From command line enter
sudo mkdir /etc/nginx/ssl
sudo openssl req -x509 -nodes -days 365 -newkey rsa:2048 -keyout /etc/nginx/ssl/nginx.key -out /etc/nginx/ssl/nginx.crt
Adding SSL - Step 2
Modify your nginx configuration file - '/etc/nginx/sites-available/default'
Add lines to 'server' section.
listen 8085 ssl;
ssl_certificate /etc/nginx/ssl/nginx.crt;
ssl_certificate_key /etc/nginx/ssl/nginx.key;
For SSL we will use 8085 port because standard 443 is used by razberry mongoos webif server.
Restart nginx.
Now you have secure SSL connection to your razberry.
And the last section
Example of settings to control razzberry remotely from javascript
The config file should look like that to allow cross origin requests
location / {
                add_header Access-Control-Allow-Origin http://localhost:8000;
                add_header Access-Control-Allow-Methods GET,POST,OPTIONS;
                proxy_hide_header  Access-Control-Allow-Origin;
The Javascript example to request sensor value via SSL and authentication.
$.ajax({
  type: 'GET',
  url: 'https://superuser:password@192.168.10.98:8085/JS/Run/controller.devices.get("ZWayVDev_zway_2-1-48-1").get("metrics:level")',
  xhrFields: {
    withCredentials: true
  data: {},
  crossDomain: true
}).done(function(data) {
  console.log("Data returned: " + data);
Re: [HowTo] Authentication for your Razberry
Thanks for sharing your knowledge
xchatter
Post by xchatter »
Thanks for this dolpheen !
Re: [HowTo] Authentication for your Razberry (using nginx)
@dolpheen
How does your solution compare to/interfere with the newly added native authentication in Zway?
