ThermostatSetPoint temperature unit incorrect in scaleTitle
jensmoes
Post by jensmoes »
If I change ThermostatSetPoint and print out the virtual device using:
JSON.stringify(virtualDevice)
It reports the unit as degrees F but the temperature values are in Celsius:
{"creatorId":2,"deviceType":"thermostat","id"
:"ZWayVDev_zway_4-0-67","location":null,"metrics":{"scaleTitle":"°F","level":27,"min":5,"max":40,"icon":"thermostat","ti
tle":"RTCA Thermostat 4-0"},"permanently_hidden":false,"tags":[],"updateTime":1430762730}
If I query the whole data object on that command class I can see that scale is set to 0 (C) but deviceScale is set to 1 (F) for both heating and cooling, so I am not sure whether to expect F or C but the combination of the two is definitely not right.
I see the same on CC 49 when the thermostat reports its temperature and I print out the JSON object.
I am running 2.0.1rc25
Is this a known issue?
Thermo.json.zip
JSON output of command class 67 data object
(579 Bytes) Downloaded 627 times
xchatter
Re: ThermostatSetPoint temperature unit incorrect in scaleTi
Post by xchatter »
Hi there,
What device are you using?
I am using ZXT-120 and the ScaleString values are OK in my case(all set to Celsius).
jensmoes
Post by jensmoes »
I am using a 2gig CT100.
Mine is set to Fahrenheit
I am curious, if you set your thermostat to Fahrenheit does it report the correct temperatures as well as scale in CC 67?
Have you tried changing Scale setting in /opt/z-way-server/config/Defaults.xml
jensmoes
Post by jensmoes »
I did change the <Fahrenheit> tag under ThermostatSetPoint to 1, it still returns the same as I have in the attached json file.
Hope the Zwave.me team can give you an answer soon
deviceScale stores scale reported by the device. scale is the one defined in Defaults.xml and shown to the user.
We are in Europe and have not tested F scale for quite some time. If it is broken, please report here: https://github.com/Z-Wave-Me/z-way-issues/issues (here, since it is related to the backend, not UI)
jensmoes
Post by jensmoes »
I reported that setting the Defaults.xml to Fahrenheit appears to have no effect on the UI.
I have no idea how this is supposed to work, but the UI certainly does not appear to be configurable based on the defaults. Whether the issue is in the backend or UI I will leave to you guys to determine :)
Thanks!
razwave
Post by razwave »
Same problem still exists on the following versions. Is there any chance this can be fixed soon?
Firmware
SDK Version: 6.51.03
Serial API Version: 05.00
Capabillities:
UUID:
Subvendor:
Nodes limit:
Capabillities:
Z-Way Software Information
Version number: v2.1.2-rc17
Compile-ID: 79d4f1a27a88ede41f1607be31da5acfc769fe74
Compile-Date: 2015-11-15 01:03:23 +0300
UI
UI version 1.0.3
Zway424
Post by Zway424 »
I have a Honeywell thermostat and I was having same problem device reporting Fahrenheit values but showing units as Celsius after updating config.xml file for fahrenheit. I forced interview of the thermostat in the expert UI and now the device reads correct value and units in Fahrenheit. Hopefully this works for you, maybe not. It's worth trying though.
