Light Scene Regression Bug - Dimmer Level
nybble
Post by nybble »
Hello all!
I just would like to report that I'm currently running v2.0.1-rc35. I have a Light Scene configured that is supposed to turn off all switches and set all dimmers to level 0.
The switches work just fine, but when I enter the value 0 into the level field and save the scene, the dimmers do not adjust after scene activation.
Reopening the scene to configure it shows that the level field is blank with the warning "This field is not optional."
nybble
Re: Light Scene Regression Bug - Dimmer Level
Post by nybble »
Just wanted to add some information to this. The configjson file that defines the apps is missing the "status": field for the dimmers when you attempt to set the level to 0.
I have manually added the "status":0 field to the LightScene in the configjson file through SSH.
Immediately after refreshing the web UI, the json file reverts back to missing the "status": field.
Quax1507
Post by Quax1507 »
Same Problem here - also in rc37!
nybble
Post by nybble »
I can confirm the issue still exists in RC37 as well.
There are a few more things not working as specified in the latest RC's (e.g. https://github.com/Z-Wave-Me/zwave-smarthome/issues/10)
Can someone confirm that this is fixed? Or we need to re-submit an issue?
nybble
Post by nybble »
I have upgraded to 2.0.1 release and the issue is still present.
Quax1507
Post by Quax1507 »
Bug is still present in 2.0.2-rc1
nybble
Post by nybble »
I can also confirm that it is still present in 2.0.2-rc1.
