Interview Failures
txb
Interview Failures
Post by txb »
I'm a relative newbie to the Z-Wave.me environment, but have been using Z-Wave in my home for some time. I just recently acquired a Razberry system, and it's up and running with v2.0.1-rc33.
The Razberry is a secondary controller in the environment. The primary is an instance of Homeseer Pro V3. After joining the network, I can see all the devices - though the interview process has been a bit hit and miss. In most cases, I have gone in and manually run each step of the interview. For a number of devices this has worked fine, and the Interview is marked as completed. But I have a few devices (mostly those that are dimmer switches) that complete all Interview steps EXCEPT the Version step. The output in the log from that Version interview is attached ... I have parsed this output, and all phases seem to indicate Success ... but the step is never marked as completed (as shown in the attached image).
My goal is to interface to Apple HomeKit, and it's mostly working, even some of the devices that have not completed the interview are controllable. But anything with a dimmer does not work, sadly. So I'm trying to clean up the devices, but I can't seem to find my way around the Interview as yet.
Any help/guidance would be appreciated.
[2015-06-07 09:39:40.978] [I] [zway] Adding job: Basic Version Get
[2015-06-07 09:39:40.979] [I] [zway] Adding job: SwitchMultilevel Version Get
[2015-06-07 09:39:40.980] [I] [zway] Adding job: SwitchAll Version Get
[2015-06-07 09:39:40.980] [I] [zway] Adding job: SceneActivation Version Get
[2015-06-07 09:39:40.981] [I] [zway] Adding job: SceneActuatorConf Version Get
[2015-06-07 09:39:40.981] [I] [zway] Adding job: ManufacturerSpecific Version Get
[2015-06-07 09:39:40.981] [I] [zway] Adding job: PowerLevel Version Get
[2015-06-07 09:39:40.982] [I] [zway] Adding job: NodeNaming Version Get
[2015-06-07 09:39:40.982] [I] [zway] Adding job: Association Version Get
[2015-06-07 09:39:40.982] [I] [zway] Adding job: Version Version Get
[2015-06-07 09:39:40.983] [D] [zway] SENDING (cb 0xc5): ( 01 0A 00 13 05 03 86 13 20 25 C5 B5 )
[2015-06-07 09:39:40.986] [D] [zway] RECEIVED ACK
[2015-06-07 09:39:40.991] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-06-07 09:39:40.992] [D] [zway] SENT ACK
[2015-06-07 09:39:40.992] [D] [zway] Delivered to Z-Wave stack
[2015-06-07 09:39:41.045] [D] [zway] RECEIVED: ( 01 07 00 13 C5 00 00 06 28 )
[2015-06-07 09:39:41.045] [D] [zway] SENT ACK
[2015-06-07 09:39:41.045] [I] [zway] Job 0x13 (Basic Version Get): Delivered
[2015-06-07 09:39:41.046] [D] [zway] SETDATA devices.5.data.lastPacketInfo.delivered = True
[2015-06-07 09:39:41.046] [D] [zway] SETDATA devices.5.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2015-06-07 09:39:41.046] [D] [zway] SETDATA devices.5.data.lastPacketInfo.deliveryTime = 54 (0x00000036)
[2015-06-07 09:39:41.046] [D] [zway] SETDATA devices.5.data.lastPacketInfo = **********
[2015-06-07 09:39:41.046] [D] [zway] SendData Response with callback 0xc5 received: received by recipient
[2015-06-07 09:39:41.046] [D] [zway] SETDATA devices.5.data.lastSend = 898629 (0x000db645)
[2015-06-07 09:39:41.046] [D] [zway] Job 0x13 (Basic Version Get): success
[2015-06-07 09:39:41.047] [I] [zway] Removing job: Basic Version Get
[2015-06-07 09:39:41.116] [D] [zway] SENDING (cb 0xc6): ( 01 0A 00 13 05 03 86 13 26 25 C6 B0 )
[2015-06-07 09:39:41.118] [D] [zway] RECEIVED ACK
[2015-06-07 09:39:41.124] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-06-07 09:39:41.124] [D] [zway] SENT ACK
[2015-06-07 09:39:41.124] [D] [zway] Delivered to Z-Wave stack
[2015-06-07 09:39:41.178] [D] [zway] RECEIVED: ( 01 07 00 13 C6 00 00 05 28 )
[2015-06-07 09:39:41.178] [D] [zway] SENT ACK
[2015-06-07 09:39:41.178] [I] [zway] Job 0x13 (SwitchMultilevel Version Get): Delivered
[2015-06-07 09:39:41.178] [D] [zway] SETDATA devices.5.data.lastPacketInfo.delivered = True
[2015-06-07 09:39:41.178] [D] [zway] SETDATA devices.5.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2015-06-07 09:39:41.178] [D] [zway] SETDATA devices.5.data.lastPacketInfo.deliveryTime = 54 (0x00000036)
[2015-06-07 09:39:41.178] [D] [zway] SETDATA devices.5.data.lastPacketInfo = **********
[2015-06-07 09:39:41.179] [D] [zway] SendData Response with callback 0xc6 received: received by recipient
[2015-06-07 09:39:41.179] [D] [zway] SETDATA devices.5.data.lastSend = 898642 (0x000db652)
[2015-06-07 09:39:41.179] [D] [zway] Job 0x13 (SwitchMultilevel Version Get): success
[2015-06-07 09:39:41.179] [I] [zway] Removing job: SwitchMultilevel Version Get
[2015-06-07 09:39:41.248] [D] [zway] SENDING (cb 0xc7): ( 01 0A 00 13 05 03 86 13 27 25 C7 B0 )
[2015-06-07 09:39:41.250] [D] [zway] RECEIVED ACK
[2015-06-07 09:39:41.256] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-06-07 09:39:41.256] [D] [zway] SENT ACK
[2015-06-07 09:39:41.256] [D] [zway] Delivered to Z-Wave stack
[2015-06-07 09:39:41.310] [D] [zway] RECEIVED: ( 01 07 00 13 C7 00 00 06 2A )
[2015-06-07 09:39:41.310] [D] [zway] SENT ACK
[2015-06-07 09:39:41.310] [I] [zway] Job 0x13 (SwitchAll Version Get): Delivered
[2015-06-07 09:39:41.310] [D] [zway] SETDATA devices.5.data.lastPacketInfo.delivered = True
[2015-06-07 09:39:41.310] [D] [zway] SETDATA devices.5.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2015-06-07 09:39:41.311] [D] [zway] SETDATA devices.5.data.lastPacketInfo.deliveryTime = 53 (0x00000035)
[2015-06-07 09:39:41.311] [D] [zway] SETDATA devices.5.data.lastPacketInfo = **********
[2015-06-07 09:39:41.311] [D] [zway] SendData Response with callback 0xc7 received: received by recipient
[2015-06-07 09:39:41.311] [D] [zway] SETDATA devices.5.data.lastSend = 898655 (0x000db65f)
[2015-06-07 09:39:41.311] [D] [zway] Job 0x13 (SwitchAll Version Get): success
[2015-06-07 09:39:41.311] [I] [zway] Removing job: SwitchAll Version Get
[2015-06-07 09:39:41.382] [D] [zway] SENDING (cb 0xc8): ( 01 0A 00 13 05 03 86 13 2B 25 C8 B3 )
[2015-06-07 09:39:41.383] [D] [zway] RECEIVED ACK
[2015-06-07 09:39:41.389] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-06-07 09:39:41.389] [D] [zway] SENT ACK
[2015-06-07 09:39:41.389] [D] [zway] Delivered to Z-Wave stack
[2015-06-07 09:39:41.443] [D] [zway] RECEIVED: ( 01 07 00 13 C8 00 00 06 25 )
[2015-06-07 09:39:41.443] [D] [zway] SENT ACK
[2015-06-07 09:39:41.443] [I] [zway] Job 0x13 (SceneActivation Version Get): Delivered
[2015-06-07 09:39:41.443] [D] [zway] SETDATA devices.5.data.lastPacketInfo.delivered = True
[2015-06-07 09:39:41.444] [D] [zway] SETDATA devices.5.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2015-06-07 09:39:41.444] [D] [zway] SETDATA devices.5.data.lastPacketInfo.deliveryTime = 54 (0x00000036)
[2015-06-07 09:39:41.444] [D] [zway] SETDATA devices.5.data.lastPacketInfo = **********
[2015-06-07 09:39:41.444] [D] [zway] SendData Response with callback 0xc8 received: received by recipient
[2015-06-07 09:39:41.444] [D] [zway] SETDATA devices.5.data.lastSend = 898668 (0x000db66c)
[2015-06-07 09:39:41.444] [D] [zway] Job 0x13 (SceneActivation Version Get): success
[2015-06-07 09:39:41.444] [I] [zway] Removing job: SceneActivation Version Get
[2015-06-07 09:39:41.515] [D] [zway] SENDING (cb 0xc9): ( 01 0A 00 13 05 03 86 13 2C 25 C9 B5 )
[2015-06-07 09:39:41.517] [D] [zway] RECEIVED ACK
[2015-06-07 09:39:41.522] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-06-07 09:39:41.523] [D] [zway] SENT ACK
[2015-06-07 09:39:41.523] [D] [zway] Delivered to Z-Wave stack
[2015-06-07 09:39:41.576] [D] [zway] RECEIVED: ( 01 07 00 13 C9 00 00 05 27 )
[2015-06-07 09:39:41.577] [D] [zway] SENT ACK
[2015-06-07 09:39:41.577] [I] [zway] Job 0x13 (SceneActuatorConf Version Get): Delivered
[2015-06-07 09:39:41.577] [D] [zway] SETDATA devices.5.data.lastPacketInfo.delivered = True
[2015-06-07 09:39:41.577] [D] [zway] SETDATA devices.5.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2015-06-07 09:39:41.577] [D] [zway] SETDATA devices.5.data.lastPacketInfo.deliveryTime = 54 (0x00000036)
[2015-06-07 09:39:41.577] [D] [zway] SETDATA devices.5.data.lastPacketInfo = **********
[2015-06-07 09:39:41.577] [D] [zway] SendData Response with callback 0xc9 received: received by recipient
[2015-06-07 09:39:41.578] [D] [zway] SETDATA devices.5.data.lastSend = 898681 (0x000db679)
[2015-06-07 09:39:41.578] [D] [zway] Job 0x13 (SceneActuatorConf Version Get): success
[2015-06-07 09:39:41.578] [I] [zway] Removing job: SceneActuatorConf Version Get
[2015-06-07 09:39:41.647] [D] [zway] SENDING (cb 0xca): ( 01 0A 00 13 05 03 86 13 72 25 CA E8 )
[2015-06-07 09:39:41.649] [D] [zway] RECEIVED ACK
[2015-06-07 09:39:41.654] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-06-07 09:39:41.655] [D] [zway] SENT ACK
[2015-06-07 09:39:41.655] [D] [zway] Delivered to Z-Wave stack
[2015-06-07 09:39:41.708] [D] [zway] RECEIVED: ( 01 07 00 13 CA 00 00 06 27 )
[2015-06-07 09:39:41.709] [D] [zway] SENT ACK
[2015-06-07 09:39:41.709] [I] [zway] Job 0x13 (ManufacturerSpecific Version Get): Delivered
[2015-06-07 09:39:41.709] [D] [zway] SETDATA devices.5.data.lastPacketInfo.delivered = True
[2015-06-07 09:39:41.709] [D] [zway] SETDATA devices.5.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2015-06-07 09:39:41.709] [D] [zway] SETDATA devices.5.data.lastPacketInfo.deliveryTime = 54 (0x00000036)
[2015-06-07 09:39:41.709] [D] [zway] SETDATA devices.5.data.lastPacketInfo = **********
[2015-06-07 09:39:41.710] [D] [zway] SendData Response with callback 0xca received: received by recipient
[2015-06-07 09:39:41.710] [D] [zway] SETDATA devices.5.data.lastSend = 898694 (0x000db686)
[2015-06-07 09:39:41.710] [D] [zway] Job 0x13 (ManufacturerSpecific Version Get): success
[2015-06-07 09:39:41.710] [I] [zway] Removing job: ManufacturerSpecific Version Get
[2015-06-07 09:39:41.779] [D] [zway] SENDING (cb 0xcb): ( 01 0A 00 13 05 03 86 13 73 25 CB E8 )
[2015-06-07 09:39:41.781] [D] [zway] RECEIVED ACK
[2015-06-07 09:39:41.787] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-06-07 09:39:41.787] [D] [zway] SENT ACK
[2015-06-07 09:39:41.787] [D] [zway] Delivered to Z-Wave stack
[2015-06-07 09:39:41.840] [D] [zway] RECEIVED: ( 01 07 00 13 CB 00 00 06 26 )
[2015-06-07 09:39:41.841] [D] [zway] SENT ACK
[2015-06-07 09:39:41.841] [I] [zway] Job 0x13 (PowerLevel Version Get): Delivered
[2015-06-07 09:39:41.841] [D] [zway] SETDATA devices.5.data.lastPacketInfo.delivered = True
[2015-06-07 09:39:41.841] [D] [zway] SETDATA devices.5.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2015-06-07 09:39:41.841] [D] [zway] SETDATA devices.5.data.lastPacketInfo.deliveryTime = 54 (0x00000036)
[2015-06-07 09:39:41.841] [D] [zway] SETDATA devices.5.data.lastPacketInfo = **********
[2015-06-07 09:39:41.841] [D] [zway] SendData Response with callback 0xcb received: received by recipient
[2015-06-07 09:39:41.841] [D] [zway] SETDATA devices.5.data.lastSend = 898707 (0x000db693)
[2015-06-07 09:39:41.842] [D] [zway] Job 0x13 (PowerLevel Version Get): success
[2015-06-07 09:39:41.842] [I] [zway] Removing job: PowerLevel Version Get
[2015-06-07 09:39:41.911] [D] [zway] SENDING (cb 0xcc): ( 01 0A 00 13 05 03 86 13 77 25 CC EB )
[2015-06-07 09:39:41.913] [D] [zway] RECEIVED ACK
[2015-06-07 09:39:41.918] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-06-07 09:39:41.919] [D] [zway] SENT ACK
[2015-06-07 09:39:41.919] [D] [zway] Delivered to Z-Wave stack
[2015-06-07 09:39:41.972] [D] [zway] RECEIVED: ( 01 07 00 13 CC 00 00 06 21 )
[2015-06-07 09:39:41.972] [D] [zway] SENT ACK
[2015-06-07 09:39:41.972] [I] [zway] Job 0x13 (NodeNaming Version Get): Delivered
[2015-06-07 09:39:41.972] [D] [zway] SETDATA devices.5.data.lastPacketInfo.delivered = True
[2015-06-07 09:39:41.972] [D] [zway] SETDATA devices.5.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2015-06-07 09:39:41.972] [D] [zway] SETDATA devices.5.data.lastPacketInfo.deliveryTime = 53 (0x00000035)
[2015-06-07 09:39:41.972] [D] [zway] SETDATA devices.5.data.lastPacketInfo = **********
[2015-06-07 09:39:41.972] [D] [zway] SendData Response with callback 0xcc received: received by recipient
[2015-06-07 09:39:41.973] [D] [zway] SETDATA devices.5.data.lastSend = 898720 (0x000db6a0)
[2015-06-07 09:39:41.973] [D] [zway] Job 0x13 (NodeNaming Version Get): success
[2015-06-07 09:39:41.973] [I] [zway] Removing job: NodeNaming Version Get
[2015-06-07 09:39:42.042] [D] [zway] SENDING (cb 0xcd): ( 01 0A 00 13 05 03 86 13 85 25 CD 18 )
[2015-06-07 09:39:42.044] [D] [zway] RECEIVED ACK
[2015-06-07 09:39:42.049] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-06-07 09:39:42.050] [D] [zway] SENT ACK
[2015-06-07 09:39:42.050] [D] [zway] Delivered to Z-Wave stack
[2015-06-07 09:39:42.104] [D] [zway] RECEIVED: ( 01 07 00 13 CD 00 00 06 20 )
[2015-06-07 09:39:42.104] [D] [zway] SENT ACK
[2015-06-07 09:39:42.104] [I] [zway] Job 0x13 (Association Version Get): Delivered
[2015-06-07 09:39:42.104] [D] [zway] SETDATA devices.5.data.lastPacketInfo.delivered = True
[2015-06-07 09:39:42.104] [D] [zway] SETDATA devices.5.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2015-06-07 09:39:42.104] [D] [zway] SETDATA devices.5.data.lastPacketInfo.deliveryTime = 54 (0x00000036)
[2015-06-07 09:39:42.105] [D] [zway] SETDATA devices.5.data.lastPacketInfo = **********
[2015-06-07 09:39:42.105] [D] [zway] SendData Response with callback 0xcd received: received by recipient
[2015-06-07 09:39:42.105] [D] [zway] SETDATA devices.5.data.lastSend = 898733 (0x000db6ad)
[2015-06-07 09:39:42.105] [D] [zway] Job 0x13 (Association Version Get): success
[2015-06-07 09:39:42.105] [I] [zway] Removing job: Association Version Get
[2015-06-07 09:39:42.175] [D] [zway] SENDING (cb 0xce): ( 01 0A 00 13 05 03 86 13 86 25 CE 18 )
[2015-06-07 09:39:42.177] [D] [zway] RECEIVED ACK
[2015-06-07 09:39:42.183] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-06-07 09:39:42.183] [D] [zway] SENT ACK
[2015-06-07 09:39:42.183] [D] [zway] Delivered to Z-Wave stack
[2015-06-07 09:39:42.237] [D] [zway] RECEIVED: ( 01 07 00 13 CE 00 00 05 20 )
[2015-06-07 09:39:42.237] [D] [zway] SENT ACK
[2015-06-07 09:39:42.237] [I] [zway] Job 0x13 (Version Version Get): Delivered
[2015-06-07 09:39:42.237] [D] [zway] SETDATA devices.5.data.lastPacketInfo.delivered = True
[2015-06-07 09:39:42.237] [D] [zway] SETDATA devices.5.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2015-06-07 09:39:42.238] [D] [zway] SETDATA devices.5.data.lastPacketInfo.deliveryTime = 54 (0x00000036)
[2015-06-07 09:39:42.238] [D] [zway] SETDATA devices.5.data.lastPacketInfo = **********
[2015-06-07 09:39:42.238] [D] [zway] SendData Response with callback 0xce received: received by recipient
[2015-06-07 09:39:42.238] [D] [zway] SETDATA devices.5.data.lastSend = 898746 (0x000db6ba)
[2015-06-07 09:39:42.238] [D] [zway] Job 0x13 (Version Version Get): success
[2015-06-07 09:39:42.238] [I] [zway] Removing job: Version Version Get
[2015-06-07 09:40:01.360] [D] [zway] Job 0x13: deleted from queue
[2015-06-07 09:40:01.483] [D] [zway] Job 0x13: deleted from queue
[2015-06-07 09:40:01.605] [D] [zway] Job 0x13: deleted from queue
[2015-06-07 09:40:01.727] [D] [zway] Job 0x13: deleted from queue
[2015-06-07 09:40:01.839] [D] [zway] Job 0x13: deleted from queue
[2015-06-07 09:40:01.961] [D] [zway] Job 0x13: deleted from queue
[2015-06-07 09:40:02.084] [D] [zway] Job 0x13: deleted from queue
[2015-06-07 09:40:02.206] [D] [zway] Job 0x13: deleted from queue
[2015-06-07 09:40:02.328] [D] [zway] Job 0x13: deleted from queue
[2015-06-07 09:40:02.451] [D] [zway] Job 0x13: deleted from queue
