Access to smart home interface
metropol
razberryID / Box ID not shown - remote access not possible
Post by metropol »
Good morning,
I have set up the Raspberry and the Razberry Z-wave module successfully.
Local access to all devices works.
now I would like to move to remote access and fail, becauseI can not see the box ID (see screenshot)
The "activate remote" box in the maintenance tab is set.
Is there any way I can read out this ID and access the system from remote?
br
thomas
Screenshot 2015-07-21 08.20.55.jpg (105.27 KiB) Viewed 5988 times
metropol
Post by metropol »
Good morning,
I have the Razberry running - I can access all things via the expert interface. However it seems I can not login via the smart home interface.
As discussed in an earlier post, the Razberry ID is not shown, but I can access the interface either via the find.z-wave.me or via the direct IP.
In both cases, I end up with an interface that asks me to login, tells me at the same time, that the first login goes via admin - admin and then I am lost.
It seems I have changed the login to this interface in the past, but I can not get back to it. Does anybody know where to set the users via command line or via the expert interface?
Thanks.
