Fibaro FGRM-222 Roller Shutter2 new Firmware 24.24 Device
ibins
Post by ibins »
Hi there,
i am using 7 Roller Shutter Devices from Fibaro right now. I bought another one. Instead of the Firmware 22.22 the new one has 24.24.
I need to configure the Device on a momentary Switch for manual up and down. I cant do that because I dont have the option anymore.
comparison to the old
Thats what I need
Fibaro Roller Shutter2old.jpg (40.12 KiB) Viewed 18468 times
nothing there in the new one. I can only add three attachements.
There it says Device has no configuration, and I can only change
Protection Settings
Local operations
updated: 09:04 | Default value is: Unprotected
RF operations
Is this device not supported? I don't need all the Features. Is it possible for me to push this option manually into the device?
Greetings
ibins
ibins
Re: Fibaro FGRM-222 Roller Shutter2 new Firmware 24.24 Devic
Post by ibins »
Hi Poltos,
is this device with the new Firmware not supported?
ibins
Isaksson
Post by Isaksson »
I would give it a try to change that from "expert command"
never tested this one. We got few new devices in our lab, will try to test soon
ibins
Post by ibins »
How would I do that?
ibins
Post by ibins »
even with the new razberry firmware not more possibilities. After talking to the fibaro support they told me that the developers of the zwave central device have to include this device in there database. Please include this device with the new firmware in your database.
I always thought that zwave is kind of a standard.
Is there a list of Devices that are really good supported by razberry. Even a manufacturer. I don't want to play arround and test everything myself.
ibins
michap
Post by michap »
try to go to expert view.
Go to configuration and select your device
-> "Expert Commands"
-> Go to "Configuration"
-> Add the "Parameter" 14 and "Value" 2
-> Press on "Set"
using the device datasheed you can configure device parameters with this method
Hope this helps and it is working for you.
Michael
ibins
Post by ibins »
So you havent't read the post. Thats what I have been doing with the older FGRM-222. With Firmware 24.24 this not possible anymore.
michap
Post by michap »
Hm.... your screen are from configuration mode page, not from Expert mode.
But maybe I misunderstand your post, then sorry..
Michael
ibins
Post by ibins »
thanks for your help. You are right, that would be the solution. I get an error Message when I try this.
Any Ideas!
Thanks for not giving up.
ibins
