Battery polling is not working automatically?
fableman
Post by fableman »
Hi
I got version : 2.0.2-rc1
All values are old.
When I click update it updates, but how to keep it update like once a day?
What do I need todo?
Isaksson
Re: Battery polling is not working automatically?
Post by Isaksson »
I think that you should activate the local App Battery polling, that will take care of this for you.
It is installed in new installations of 2.0.2-rc1, but does not come if you upgrade from a previous version
fableman
Post by fableman »
It's an upgrade.
Is it this App "Poll sensors and log values periodically" I need and
I must include all the battery devices manually now?
or the App "Sensor Values Logging" ?
Abit confusing to know what I need. I normally only use the expert mode and code my own stuff.
The temperature been working all the time without any polling apps.
I don't have any Apps active at all.
fableman wrote:I must include all the battery devices manually now?
There is a dedicated scheduling app Battery Polling that you can install. It reports once a week, and you can set the warning level
fableman
Post by fableman »
I don't have any app named Battery Polling :( I checked very carefull.
Should I try install z-way-server-RaspberryPiXTools-v2.0.2-rc2-beta-1-g500b32e.tgz ?
fableman
Post by fableman »
Now installed and same problem. there is no battery polling app :(
I cleared all my active apps and battery don't show up in local apps..
What can I do ?
My install log:
root@zwave-raspberrypi:~# wget -O - razberry.z-wave.me/install/v2.0.2-rc2-beta-1-g500b32e | sudo bash
--2015-08-05 21:02:59--  http://razberry.z-wave.me/install/v2.0.2-rc2-beta-1-g500b32e
Resolving razberry.z-wave.me (razberry.z-wave.me)... 46.20.244.36
Connecting to razberry.z-wave.me (razberry.z-wave.me)|46.20.244.36|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [text/plain]
Saving to: `STDOUT'
    [<=>        ] 0           --.-K/s              Removing MathKernel
Reading package lists... Done
    [ <=>        ] 16,161      --.-K/s   in 0.07s
2015-08-05 21:02:59 (234 KB/s) - written to stdout [16161]
Building dependency tree
Reading state information... Done
Package 'wolfram-engine' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 105 not upgraded.
Installing additional libraries
Hit http://raspberrypi.collabora.com wheezy Release.gpg
Hit http://mirrordirector.raspbian.org wheezy Release.gpg
Hit http://archive.raspberrypi.org wheezy Release.gpg
Hit http://raspberrypi.collabora.com wheezy/rpi armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/main armhf Packages
Hit http://archive.raspberrypi.org wheezy/main armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/contrib armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/non-free armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/rpi armhf Packages
Ign http://raspberrypi.collabora.com wheezy/rpi Translation-en_GB
Ign http://archive.raspberrypi.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/rpi Translation-en_GB
Building dependency tree...
gawk is already the newest version.
sharutils is already the newest version.
tzdata is already the newest version.
Installing additional libraries for HomeKit
libavahi-compat-libdnssd-dev is already the newest version.
Getting Z-Way for Raspberry Pi and installing
--2015-08-05 21:03:42--  http://razberry.z-wave.me/z-way-server/z-way-server-RaspberryPiXTools-v2.0.2-rc2-beta-1-g500b32e.tgz
Length: 15842110 (15M) [application/x-gzip]
Saving to: `/tmp/z-way-server-RaspberryPiXTools-v2.0.2-rc2-beta-1-g500b32e.tgz'
100%[=======================================================================================================================>] 15,842,110  1.58M/s   in 9.9s
2015-08-05 21:03:52 (1.53 MB/s) - `/tmp/z-way-server-RaspberryPiXTools-v2.0.2-rc2-beta-1-g500b32e.tgz' saved [15842110/15842110]
Extracting new z-way-server
Previous z-way-server installation found
Stopping z-way-server: done.
Making backup of previous version of Z-Way in /opt/z-way-server_2015-08-05-21-03-55
Copying settings
config.xml replaced by the new one - make sure to restore your changes
diff /opt/z-way-server/config.xml /opt/z-way-server_2015-08-05-21-03-55/config.xml:
3c3
<     <log-file>/var/log/z-way-server.log</log-file>
>     <log-file>/mnt/ramdrive/z-way-server.log</log-file>
!!! Defaults.xml and config.xml updated with new versions !!!
Creating Z-Way startup script
Adding z-way-server to autostart
update-rc.d: using dependency based boot sequencing
Getting Webif for Raspberry Pi and installing
--2015-08-05 21:03:55--  http://razberry.z-wave.me/webif_raspberry.tar.gz
Length: 401379 (392K) [application/x-gzip]
Saving to: `STDOUT'
100%[=======================================================================================================================>] 401,379     1008K/s   in 0.4s
2015-08-05 21:03:56 (1008 KB/s) - written to stdout [401379/401379]
[....] Stoping zbw_connect:[info] ok.
zbw_connect patched
[....] Starting zbw_connect:[info] ok.
Removing duplicate of mongoose
Getting webserver mongoose for Webif
--2015-08-05 21:03:56--  http://razberry.z-wave.me/mongoose.pkg.rPi.tgz
Length: 44749 (44K) [application/x-gzip]
Saving to: `/tmp/mongoose.pkg.rPi.tgz'
100%[=======================================================================================================================>] 44,749      --.-K/s   in 0.1s
2015-08-05 21:03:56 (414 KB/s) - `/tmp/mongoose.pkg.rPi.tgz' saved [44749/44749]
Stopping mongoose http server
Adding mongoose to autostart
Start mongoose http server
Opened config/zddx/0184e528-DevicesData.xml
Opened config/zddx/faf9d597-DevicesData.xml
Starting z-way-server
Starting z-way-server: done.
Thank you for using RaZberry!
fableman
Post by fableman »
I found the problem...
Under my Settings
I activated : "Show System Apps" ( you should remove this option )
Now I can see the Battery App.
fableman
Post by fableman »
one more question what time xx:xx ? dose the battery app check the devices?
(it don't show, only every day or Sunday, I need to know the hour)
You have sources ;)
automation/modules/BatteryPolling/index.js
