2.0.2-rc3 + requests on localhost failing
jsimon
Post by jsimon »
I'm running 2.0.2-rc3. I can make authenticated requests externally to the RPi running Z-Way. If I make the same requests locally to 127.0.0.1, I either get an empty list of devices or a 404 because the device ID i specify is not a valid device ID. The same exact request to the LAN IP of the RPi, if authenticated, work properly.
Anybody else seeing this?
Re: 2.0.2-rc3 + requests on localhost failing
There is a local uses I suppose. Remove it or give him more priviledge
