No Active Apps in UI
jet11x
Post by jet11x »
On saving setting for a module I found z-wave had crashed and wouldn't work any more.
I managed to get it running again by using an older config.json.
However, I know don't see any active apps and can't add new ones.
I saw one error on the log file:
[E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
I suspect something is still wrong with the config file, but I'm not sure what.
Appreciate any assistance.
I'm on version 2.0.1
Re: No Active Apps in UI
Without full log (by mail, please) or at least short extracts it is hard to help you.
jet11x
Post by jet11x »
Thanks for your rapid response.
I've emailed the log and also my config.json file
May be clear cache?
jet11x
Post by jet11x »
Browser restart seems to have done the trick thanks.
I had tried another browser (IE) but that has mis-lead me as it had a different problem.
