I expected I could just specify ZWay user name/password in the OpenRemote HTTP call specification form, as I have done with several other places that need authentication. Unfortunately this does not work with ZWay. Also typing the url prefixed with the user/password in webbrowser tells me that access is refused.
I am aware of the solution described in the FAQ that uses curl. I don't know how that would work with this OpenRemote configurator.
What am I missing to make it easy for OR users?
OpenRemote does not authenticate with ZWay
Re: OpenRemote does not authenticate with ZWay
use post instead of get works perfectly!!:)
- OR pro z-way
- lampkaor.jpg (25.81 KiB) Viewed 17531 times
That is not the problem. I did try both post and get. I do notice that your example does not contain username/password. Similarly a call from the browser in the formtaftek wrote:use post instead of get works perfectly!!:)
http://admin:admin@raspberrypi:8083/OpenRemote/SwitchBinaryStatus/9/0Re: OpenRemote does not authenticate with ZWay
Basic auth user:passwd@host/uri will work from the next release
Thanks, next reliefPoltoS wrote:Basic auth user:passwd@host/uri will work from the next release
I'm not really sure about user:passwd@host, but Authorization Basic header will do.
Should that work with v2.1.2-rc2, or still a later version?pofs wrote: but Authorization Basic header will do.
It even worked with 2.1.2-rc1pz1 wrote:Should that work with v2.1.2-rc2, or still a later version?pofs wrote: but Authorization Basic header will do.
Then I have a serious problem I am afraid
With authentication the standard OpenRemote doesn't seem to do what you call "basic authentication"
note:OpenRemote has shown to be working with other user/pw protected http sources.
OpenRemote log says:
I'll also dig a bit in OR forums/docs
2015-09-15 19:04:54,938 ERROR [Polling Sensor Thread ID = 248217, Name ='Duwi']: ClientProtocolException when executing HTTP method
org.apache.http.client.HttpResponseException: Forbidden
at org.apache.http.impl.client.BasicResponseHandler.handleResponse(BasicResponseHandler.java:67)
at org.apache.http.impl.client.BasicResponseHandler.handleResponse(BasicResponseHandler.java:54)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:735)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:709)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:700)
at org.openremote.controller.protocol.http.HttpGetCommand.requestURL(Unknown Source)
at org.openremote.controller.protocol.http.HttpGetCommand.read(Unknown Source)
at org.openremote.controller.model.sensor.Sensor$DeviceReader.read(Unknown Source)
at org.openremote.controller.model.sensor.Sensor$DeviceReader.run(Unknown Source)
at java.lang.Thread.run(Thread.java:745)Re: OpenRemote does not authenticate with ZWay
Then check your requests from OR side, probably it uses some other kind of authorization rather than Basic.
Compare my two outputs.
First one is anonymous request:
Second one is basic auth request:
As you can see, the only difference is Authorization header present in second request, so basic auth actually looks like working ok. Please try the same for your specific url, and compare the output.
MacBook-Air:automation pieceofsummer$ curl -v http://127.0.0.1:8083/ZAutomation/api/v1/devices/OpenWeather_21
> GET /ZAutomation/api/v1/devices/OpenWeather_21 HTTP/1.1
> Host: 127.0.0.1:8083
> User-Agent: curl/7.43.0
> Accept: */*
< HTTP/1.1 404 Not Found
< Content-Type: application/json; charset=utf-8
< X-API-VERSION: 2.0.1
< Date: Tue, 15 Sep 2015 18:30:08 GMT
< Access-Control-Expose-Headers: Accept-Ranges, Content-Encoding, Content-Length, Content-Range, Content-Type, ETag, X-API-VERSION, Date, Cache-Control, If-None-Match, Content-Language, Accept-Language, ZWAYSession
< Access-Control-Allow-Origin: *
< Access-Control-Allow-Methods: GET, POST, PUT, DELETE, OPTIONS
< Connection: close
< Access-Control-Allow-Credentials: true
< Content-Length: 96
< Transfer-Encoding: chunked
{"data":null,"code":404,"message":"404 Not Found","error":"Device OpenWeather_21 doesn't exist"}
MacBook-Air:automation pieceofsummer$ curl -v -u admin:admin http://127.0.0.1:8083/ZAutomation/api/v1/devices/OpenWeather_21
* Server auth using Basic with user 'admin'
> Authorization: Basic YWRtaW46YWRtaW4=
> Accept: */*
< HTTP/1.1 200 OK
< Date: Tue, 15 Sep 2015 18:29:56 GMT
< Connection: close
< Content-Length: 669
{"data":{"creatorId":21,"deviceType":"sensorMultiline","h":-1611286412,"hasHistory":false,"id":"OpenWeather_21","location":0,"metrics":{"scaleTitle":"°C","title":"Kiev","probeTitle":"Temperature","zwaveOpenWeather":{"main":{"temp":289.03,"pressure":1021,"humidity":67,"temp_min":288.15,"temp_max":290.15},"weather":[{"id":800,"main":"Clear","description":"clear sky","icon":"01n"}],"wind":{"speed":3,"deg":130}},"level":15.9,"icon":"http://openweathermap.org/img/w/01n.png","country":"UA","flag":"http://openweathermap.org/images/flags/ua.png"},"permanently_hidden":false,"tags":[],"visibility":true,"updateTime":1442341731},"code":200,"message":"200 OK","error":null}
