Openremote Razberry auto-discovery
taftek
Post by taftek »
Openremote /Openremote pro works great with z-way server through z-way API with openremote helpers but it will be great to develop OR module similar to vera module which automatically import commands from server to OR
Re: Openremote Razberry auto-discovery
There have been endless discussions with the OpenRemote team, but since their development budget is virtually zero, nothing materialised. Unfortunately their auto discovery algoritms are not in the open publicly available sources. So it is hard to make progress there. On the ZWay side, OpenRemote could use the Z-Wave API, but they could also consider to inteface with the Virtual HA engine. That is were focus of front-ends like Androis clients, Homekit and iRidium mobile are. (The OpenRemoteHelpers API is not recommended because of its deliberatwe limited functionality)
I have the feeling they are gradually moving away from the open source world, which as aptly decribed by Pieter Hintjens is a typical emerging life cycle.
In the meantime imho ZWay has progressed significantly, and is actively maintained. It is not that difficult to add other protocols to ZWay. Enocean has recently be added, XML, http, udp, tcp are there. . So for me the use of OR is reduced to mostly a visualisation platform.
If OpenRemote had an (preferrably) XML import facility, it would not be too complicated to create an export module within ZWay that produces such an output. (JSON could do as well, but I beleive XML is to be preferred for exchange between dissimilar systems)
taftek
Post by taftek »
Openremote pro + z-way it is best soloution .z-way runs practically on any hardware and openremote provides customized GUI and very IR support. z-way works perfectly on platform such small as Galileo or Edison .Next week we provide new tempate for z-way.
PS.z-way on intell edison stable work
edison with z-way
edison with z-way
taftek wrote:Openremote pro + z-way it is best soloution .z-way runs practically on any hardware and openremote provides customized GUI and very IR support. z-way works perfectly on platform such small as Galileo or Edison .Next week we provide new tempate for z-way.
I fully agree it is a good combo, but if nothing happens on the OpenRemote side, there will be no progress with respect to the integration. Defining an exchange format imho is the most feasible, versatile and generic solution.
