Here's a module a few of you may find useful. I based it off of the Smart Light module written by Yurkin Vitaliy. it specifically uses the Aeotec 4 in 1 multisensor. For those of you who don't know what this sensor is, it can detect motion, sense the luminosity level, the humidity and temperature. I use all sensors in this module except the temperature. The primary application I use this in is my bathroom. When someone walks in, it turns the light on if the luminosity levels are below the specified value the user chooses. During the night, you can specify the dimmer level value so that when it detect motion the level isn't turned on full blinding you. Extract the zip file in /opt/z-way-server/automation/userModules directory and restart z-way-server. Be sure the folder name is 'AeonMultiSensor'.
This is compatible with the latest version 2.1.1. I've been using this for more than 6 months now with any issues. The icon for some reason isn't displaying on the local apps page but displays on the active apps page. Not sure why that is.
[userModule] AeonMultiSensor
- AeonMultiSensor.zip
- (44.73 KiB) Downloaded 566 times
Re: [userModule] AeonMultiSensor
Thanks for sharing this with us. I hope others who have been "wrestling" with this multi sensor will take your module for a ride.
I think the issue is that you are using space in the name for your app (module.json)islipfd19 wrote:The icon for some reason isn't displaying on the local apps page but displays on the active apps page. Not sure why that is.
"moduleName":"Aeon Multi Sensor",
That was the problem. I've uploaded a modified version. thanks!Isaksson wrote:I think the issue is that you are using space in the name for your app (module.json)islipfd19 wrote:The icon for some reason isn't displaying on the local apps page but displays on the active apps page. Not sure why that is.Code: Select all
