Max number of devices (1) reached
minipli
Post by minipli »
In fact, I seem to have a very similar bug as Dridl had here: https://forum.z-wave.me/viewtopic.php?t=21983&p=57998. I'm also using a ZME_UZB1 and get that very same log message when trying to start "inclusion mode". Unfortunately no solution was posted, so I'm rather clueless what to do here? :(
How to detect if this is a licensing issue? And what to do in this case?
I can provide full logs, if needed.
Re: Max number of devices (1) reached
Please provide full log from start to load of devices. Do you have clean UZB1 or you have a license loaded (more correct: are you expected to have it)?
minipli
Post by minipli »
Well, I expect it to "just work". I wasn't aware that a license is required, or even that it can be obtained separately, before searching the Internet for similar error reports and finding this forum.
Log's attached.
z-way-server.log.gz
Log file
(26.88 KiB) Downloaded 344 times
minipli
Post by minipli »
PoltoS, did already you had time to look at the log file?
Your UZB have no license loaded. You need to buy a license (or get it from your shop if you payed for it).
Here you can get more info on pricing:
http://store.zwaveeurope.com/advanced_s ... zb&x=0&y=0
