I want to control my RaZberry manually by using HTTP requests.
So far, I figured out how to enable inclusion mode:
http://<my_razberry_IP>:8083/ZWaveAPI/Run/controller.AddNodeToNetwork(1)
Then I set my devices into inclusion mode, wait some time and then I stop inclusion mode:
http://<my_razberry_IP>:8083/ZWaveAPI/Run/controller.AddNodeToNetwork(0)
Now, how do I know exactly which devices have been added?
Or alternatively, how can I get a list of all connected devices without getting all JSON data belonging to each device? (I just want a list of numbers like "3,4,5" to see that z-wave devices with id 3, 4 and 5 have been added. Or a list like "1,2,3,4,5" to know that devices with ID 1 to 5 are connected)
However, now that my devices are connected I can use them assuming I found out which device IDs they are. This is easy for things like switches, lights, etc because I just need to set their values.
First, I need to set the target for the Routing Alarm Sensor to the razberry controller.
Second, I need to get notified if the alarm occurred by the controller.
How to achieve this by using the ZWaveAPI (via HTTP requests)?
Thanks a lot!
Keram
