Cannot access the ui
rm65453
Post by rm65453 »
Hi everyone,
I have been trying to make a backup of my razberry but cannot access the gui on 8083 port. the 8084 port is working fine.
here is my start up log
Z-Way version v2.1.1 from 2015-09-02 15:34:21 +0300 (build 9758c27c9115509143f3e5faaaa22f7db4dde2b5)
Looking for modules in ./modules
cURL 7.26.0 likely has DNS timeout bug. Please update cURL. Disabling sync DNS timeouts for now.
Module modinstaller.so loaded
Module modhomekit.so loaded
Module modhttp.so loaded
Module modws.so loaded
Module modzbw.so loaded
Module modsockets.so loaded
Module modcrypto.so loaded
Module modzwave.so loaded
Module modenocean.so loaded
Module moddhs.so loaded
Error: 'debug-port' number is out of range. Skipping it.
Failed to open log file: 13
[2015-10-05 17:32:38.966] [I] [core] Executing script: /*** Z-Way Home Automation Engine main executable ***************************** ...
[2015-10-05 17:32:38.968] [I] [core] Executing script: // Comon utilities and functions ...
[2015-10-05 17:32:38.978] [I] [core] Executing script: // This script transforms old formats to new ...
[2015-10-05 17:32:39.035] [I] [core] Executing script: /*! ...
[2015-10-05 17:32:39.079] [I] [core] Executing script: //     Underscore.js 1.7.0 ...
[2015-10-05 17:32:39.125] [I] [core] Executing script: /*** Z-Way HA Virtual Device base class *************************************** ...
[2015-10-05 17:32:39.131] [I] [core] Executing script: /*** Z-Way DevicesCollection class ************************************ ...
[2015-10-05 17:32:39.169] [I] [core] Executing script: /*** Z-Way HA Controller class module ***************************************** ...
[2015-10-05 17:32:39.178] [I] [core] Executing script: /*** Automation Webserver Auth Controller ************************************* ...
[2015-10-05 17:32:39.181] [I] [core] Executing script: /*** Z-Way HA Automation module base class ************************************ ...
[2015-10-05 17:32:39.184] [I] [core] Executing script:  ...
edit: tried to reinstall, here is the output
$ sudo wget -q -O - razberry.z-wave.me/install | sudo bash
Removing MathKernel
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package 'wolfram-engine' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 37 not upgraded.
Installing additional libraries
Get:1 http://mirrordirector.raspbian.org wheezy Release.gpg [490 B]
Hit http://raspberrypi.collabora.com wheezy Release.gpg
Get:2 http://archive.raspberrypi.org wheezy Release.gpg [473 B]
Get:3 http://mirrordirector.raspbian.org wheezy Release [14.4 kB]
Get:4 http://archive.raspberrypi.org wheezy Release [17.6 kB]
Hit http://raspberrypi.collabora.com wheezy/rpi armhf Packages
Get:5 http://mirrordirector.raspbian.org wheezy/main armhf Packages [6,908 kB]
Get:6 http://archive.raspberrypi.org wheezy/main armhf Packages [135 kB]
Ign http://raspberrypi.collabora.com wheezy/rpi Translation-en_GB
Ign http://archive.raspberrypi.org wheezy/main Translation-en_GB
Get:7 http://mirrordirector.raspbian.org wheezy/contrib armhf Packages [23.6 kB]
Get:8 http://mirrordirector.raspbian.org wheezy/non-free armhf Packages [49.3 kB]
Get:9 http://mirrordirector.raspbian.org wheezy/rpi armhf Packages [592 B]
Ign http://mirrordirector.raspbian.org wheezy/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/rpi Translation-en_GB
Fetched 7,149 kB in 28s (254 kB/s)
Building dependency tree...
gawk is already the newest version.
sharutils is already the newest version.
tzdata is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 38 not upgraded.
Installing additional libraries for HomeKit
libavahi-compat-libdnssd-dev is already the newest version.
Getting Z-Way for Raspberry Pi and installing
--2015-10-06 05:48:07--  http://razberry.z-wave.me/z-way-server/z-way-server-RaspberryPiXTools-v2.1.1.tgz
Resolving razberry.z-wave.me (razberry.z-wave.me)... 46.20.244.36
Connecting to razberry.z-wave.me (razberry.z-wave.me)|46.20.244.36|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 15865798 (15M) [application/x-gzip]
Saving to: `/tmp/z-way-server-RaspberryPiXTools-v2.1.1.tgz'
100%[=======================================================================================================================>] 15,865,798   707K/s   in 24s
2015-10-06 05:48:32 (640 KB/s) - `/tmp/z-way-server-RaspberryPiXTools-v2.1.1.tgz' saved [15865798/15865798]
Extracting new z-way-server
Previous z-way-server installation found
Stopping z-way-server: done.
Making backup of previous version of Z-Way in /opt/z-way-server_2015-10-06-05-48-38
Copying settings
cp: cannot stat `/opt/z-way-server_2015-10-06-05-48-38/config/Configuration.xml': No such file or directory
!!! Defaults.xml and config.xml updated with new versions !!!
Creating Z-Way startup script
Adding z-way-server to autostart
update-rc.d: using dependency based boot sequencing
Getting Webif for Raspberry Pi and installing
--2015-10-06 05:48:57--  http://razberry.z-wave.me/webif_raspberry.tar.gz
Length: 401379 (392K) [application/x-gzip]
Saving to: `STDOUT'
100%[=======================================================================================================================>] 401,379      394K/s   in 1.0s
2015-10-06 05:48:58 (394 KB/s) - written to stdout [401379/401379]
[....] Stoping zbw_connect:[info] ok.
zbw_connect patched
[....] Starting zbw_connect:[info] ok.
Getting webserver mongoose for Webif
--2015-10-06 05:48:59--  http://razberry.z-wave.me/mongoose.pkg.rPi.tgz
Length: 44749 (44K) [application/x-gzip]
Saving to: `/tmp/mongoose.pkg.rPi.tgz'
100%[=======================================================================================================================>] 44,749      87.6K/s   in 0.5s
2015-10-06 05:49:00 (87.6 KB/s) - `/tmp/mongoose.pkg.rPi.tgz' saved [44749/44749]
Stopping mongoose http server
Adding mongoose to autostart
Start mongoose http server
ls: cannot access config/zddx/*.xml: No such file or directory
Usage: ./z-cfg-update <filename>
Starting z-way-server
Starting z-way-server: done.
Thank you for using RaZberry!
Re: Cannot access the ui
What is your OS?
Please show full log of z-way-server start.
rm65453
Post by rm65453 »
i am running
Distributor ID: Debian
Description: Debian GNU/Linux 7.8 (wheezy)
Release: 7.8
Codename: wheezy
log
[2015-10-06 16:20:49.073] [I] [core] Executing script: /*** Z-Way Home Automation Engine main executable ***************************** ...
[2015-10-06 16:20:49.075] [I] [core] Executing script: // Comon utilities and functions ...
[2015-10-06 16:20:49.084] [I] [core] Executing script: // This script transforms old formats to new ...
[2015-10-06 16:20:49.150] [I] [core] Executing script: /*! ...
[2015-10-06 16:20:49.194] [I] [core] Executing script: // Underscore.js 1.7.0 ...
[2015-10-06 16:20:49.242] [I] [core] Executing script: /*** Z-Way HA Virtual Device base class *************************************** ...
[2015-10-06 16:20:49.250] [I] [core] Executing script: /*** Z-Way DevicesCollection class ************************************ ...
[2015-10-06 16:20:49.288] [I] [core] Executing script: /*** Z-Way HA Controller class module ***************************************** ...
[2015-10-06 16:20:49.296] [I] [core] Executing script: /*** Automation Webserver Auth Controller ************************************* ...
[2015-10-06 16:20:49.299] [I] [core] Executing script: /*** Z-Way HA Automation module base class ************************************ ...
[2015-10-06 16:20:49.301] [I] [core] Executing script: ...
[2015-10-06 16:39:03.205] [I] [core] Executing script: /*** Z-Way Home Automation Engine main executable ***************************** ...
[2015-10-06 16:39:03.207] [I] [core] Executing script: // Comon utilities and functions ...
[2015-10-06 16:39:03.215] [I] [core] Executing script: // This script transforms old formats to new ...
[2015-10-06 16:39:03.271] [I] [core] Executing script: /*! ...
[2015-10-06 16:39:03.314] [I] [core] Executing script: // Underscore.js 1.7.0 ...
[2015-10-06 16:39:03.362] [I] [core] Executing script: /*** Z-Way HA Virtual Device base class *************************************** ...
[2015-10-06 16:39:03.369] [I] [core] Executing script: /*** Z-Way DevicesCollection class ************************************ ...
[2015-10-06 16:39:03.406] [I] [core] Executing script: /*** Z-Way HA Controller class module ***************************************** ...
[2015-10-06 16:39:03.414] [I] [core] Executing script: /*** Automation Webserver Auth Controller ************************************* ...
[2015-10-06 16:39:03.417] [I] [core] Executing script: /*** Z-Way HA Automation module base class ************************************ ...
[2015-10-06 16:39:03.419] [I] [core] Executing script: ...
rm65453
Post by rm65453 »
so i reinstalled everything. this time i used the jessie version.
everything works fine and I am able to access the expert gui but unfortunately i get the following error
"Error handling data from server
resolve via thread: viewtopic.php?f=3422&t=22134
