Delayed event, cause?
hannez82
Post by hannez82 »
Today when i opened my front door the razberry didn't get the event. About 10 minutes later I got an event that I think was the event that didn't arrive earlier. The open and close event was extremely close together.
Is there a way to see when the event left the sensor? I'm interested to know if it was the sensor or the razberry that failed. Perhaps I'm missing something obvious here? Is the sensor in sleep or anything like that? Here is the log:
[2015-10-19 08:33:17.681] [zway] Job 0x13 (Wakeup Sleep): Cancelling job: Wakeup Sleep
[2015-10-19 08:33:17.681] [zway] Removing job: Wakeup Sleep
[2015-10-19 08:33:17.681] [zway] Adding job: MultiCmd, SensorBinary Get v2, SensorBinary Get v2, SensorMultilevel V5 Get, SensorMultilevel V5 Get, Alarm Get (v3)
[2015-10-19 08:33:17.682] [D] [zway] SETDATA devices.2.instances.0.commandClasses.132.data.lastSleep = 1445236397 (0x56248ead)
[2015-10-19 08:33:17.682] [zway] Node 2:0 CC Wakeup: Send node to sleep
[2015-10-19 08:33:17.682] [zway] Adding job: Wakeup Sleep
[2015-10-19 08:33:17.682] [D] [zway] SENDING (cb 0x28): ( 01 22 00 13 02 1B 8F 01 05 03 30 02 08 03 30 02 0A 04 31 04 01 08 04 31 04 03 00 05 71 04 00 06 00 05 28 0F )
[2015-10-19 08:33:17.684] [D] [zway] RECEIVED: ( 01 24 00 04 00 02 1E 8F 01 04 03 80 03 64 09 71 05 00 00 00 FF 06 16 00 05 31 05 03 01 03 06 31 05 01 0A 00 44 72 )
[2015-10-19 08:33:17.684] [D] [zway] SENT ACK
[2015-10-19 08:33:17.684] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2015-10-19 08:33:17.684] [D] [zway] SETDATA devices.2.instances.0.commandClasses.128.data.history.100 = 1445236397 (0x56248ead)
[2015-10-19 08:33:17.684] [D] [zway] SETDATA devices.2.instances.0.commandClasses.128.data.last = 100 (0x00000064)
[2015-10-19 08:33:17.685] [D] [zway] SETDATA devices.2.instances.0.commandClasses.113.data.6.eventParameters = byte[0]
[2015-10-19 08:33:17.685] [D] [zway] ( zero-length buffer )
[2015-10-19 08:33:17.685] [D] [zway] SETDATA devices.2.instances.0.commandClasses.113.data.6.event = 22 (0x00000016)
[2015-10-19 08:33:17.687] [D] [zway] SETDATA devices.2.instances.0.commandClasses.113.data.6.eventString = ""
[2015-10-19 08:33:17.688] [D] [zway] SETDATA devices.2.instances.0.commandClasses.113.data.6.status = 255 (0x000000ff)
[2015-10-19 08:33:17.688] [D] [zway] SETDATA devices.2.instances.0.commandClasses.113.data.6 = Empty
[2015-10-19 08:33:17.688] [D] [zway] SETDATA devices.2.instances.0.commandClasses.49.data.3.deviceScale = 0 (0x00000000)
[2015-10-19 08:33:17.688] [D] [zway] SETDATA devices.2.instances.0.commandClasses.49.data.3.scale = 0 (0x00000000)
[2015-10-19 08:33:17.688] [D] [zway] SETDATA devices.2.instances.0.commandClasses.49.data.3.val = 3.000000
[2015-10-19 08:33:17.690] [D] [zway] SETDATA devices.2.instances.0.commandClasses.49.data.3.scaleString = "%"
[2015-10-19 08:33:17.690] [D] [zway] SETDATA devices.2.instances.0.commandClasses.49.data.3 = Empty
[2015-10-19 08:33:17.691] [D] [zway] SETDATA devices.2.instances.0.commandClasses.49.data.1.deviceScale = 1 (0x00000001)
[2015-10-19 08:33:17.691] [D] [zway] SETDATA devices.2.instances.0.commandClasses.49.data.1.val = 20.000000
[2015-10-19 08:33:17.692] [D] [zway] SETDATA devices.2.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2015-10-19 08:33:17.693] [D] [zway] SETDATA devices.2.instances.0.commandClasses.49.data.1.scaleString = "<C2><B0>C"
[2015-10-19 08:33:17.693] [D] [zway] SETDATA devices.2.instances.0.commandClasses.49.data.1 = Empty
[2015-10-19 08:33:17.693] [D] [zway] RECEIVED CAN
[2015-10-19 08:33:17.700] [W] [zway] Received SOF, while awaiting ACK
[2015-10-19 08:33:17.702] [core] Hannes:1:MainDoor temperature:20
[2015-10-19 08:33:17.703] [D] [zway] RECEIVED: ( 01 24 00 04 00 02 1E 8F 01 04 03 80 03 64 09 71 05 00 00 00 FF 06 17 00 05 31 05 03 01 01 06 31 05 01 0A 00 44 71 )
[2015-10-19 08:33:17.704] [D] [zway] SENT ACK
[2015-10-19 08:33:17.704] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2015-10-19 08:33:17.704] [D] [zway] SETDATA devices.2.instances.0.commandClasses.128.data.history.100 = 1445236397 (0x56248ead)
[2015-10-19 08:33:17.704] [D] [zway] SETDATA devices.2.instances.0.commandClasses.128.data.last = 100 (0x00000064)
[2015-10-19 08:33:17.704] [D] [zway] SETDATA devices.2.instances.0.commandClasses.113.data.6.eventParameters = byte[0]
[2015-10-19 08:33:17.704] [D] [zway] ( zero-length buffer )
[2015-10-19 08:33:17.704] [D] [zway] SETDATA devices.2.instances.0.commandClasses.113.data.6.event = 23 (0x00000017)
[2015-10-19 08:33:17.706] [D] [zway] SETDATA devices.2.instances.0.commandClasses.113.data.6.eventString = ""
[2015-10-19 08:33:17.706] [D] [zway] SETDATA devices.2.instances.0.commandClasses.113.data.6.status = 255 (0x000000ff)
[2015-10-19 08:33:17.707] [D] [zway] SETDATA devices.2.instances.0.commandClasses.113.data.6 = Empty
[2015-10-19 08:33:17.707] [D] [zway] SETDATA devices.2.instances.0.commandClasses.49.data.3.deviceScale = 0 (0x00000000)
[2015-10-19 08:33:17.707] [D] [zway] SETDATA devices.2.instances.0.commandClasses.49.data.3.scale = 0 (0x00000000)
[2015-10-19 08:33:17.707] [D] [zway] SETDATA devices.2.instances.0.commandClasses.49.data.3.val = 1.000000
[2015-10-19 08:33:17.709] [D] [zway] SETDATA devices.2.instances.0.commandClasses.49.data.3.scaleString = "%"
[2015-10-19 08:33:17.709] [D] [zway] SETDATA devices.2.instances.0.commandClasses.49.data.3 = Empty
[2015-10-19 08:33:17.709] [D] [zway] SETDATA devices.2.instances.0.commandClasses.49.data.1.deviceScale = 1 (0x00000001)
[2015-10-19 08:33:17.710] [D] [zway] SETDATA devices.2.instances.0.commandClasses.49.data.1.val = 20.000000
[2015-10-19 08:33:17.710] [D] [zway] SETDATA devices.2.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2015-10-19 08:33:17.712] [D] [zway] SETDATA devices.2.instances.0.commandClasses.49.data.1.scaleString = "<C2><B0>C"
[2015-10-19 08:33:17.712] [D] [zway] SETDATA devices.2.instances.0.commandClasses.49.data.1 = Empty
hannez82
Re: Delayed event, cause?
Post by hannez82 »
]The sensor that was deleyed seems to be in sleep mode more or less all the time but my other door sensor is not. How come? It's exatctly the same sensors. The name of the device that failed was "MainDoor", it also don't have the "security" flag. What does that mean?
[attachment=0]sensor2.png[/attachment
hannez82
Post by hannez82 »
Sorry for spam but I think I resolved this. For some reason the "interview" didn't work when I connected in and a forced interview didnt work either. I decoupled the sensor and connected it again and now it works like the other.
