How to remove device
qbawawa
Post by qbawawa »
I have broken device, that I can't exclude via expert UI. Is it possible to remove it somehow manually?
Re: How to remove device
Please use Remove Failed
qbawawa
Post by qbawawa »
It's not so simple :) Broken device is not even powered now, but still is not listed on the Remove Failed field.
Got to Status tab and press Check connectivity. Then it will be added to the list of Failed and you can remove it as failed.
