Secure inclusion timeout
geirgp
Post by geirgp »
I just got the UZB1+ZWAY up and running and am trying to set up the network.
So far I've tried 4 different devices and two of them seems to have failed partially during the interview with the error "Secure inclusion timeout":
* Fibaro Smoke Sensor (FGSD-002 EU)
* Smart Switch Gen 5 (ZW07-C16)
z-way log:
[2015-11-13 19:37:55.874] [I] [zway] Node 6:0 CC Security Interview started
[2015-11-13 19:37:55.874] [I] [zway] Node 6:0 CC Security: sending Scheme Get
[2015-11-13 19:37:55.874] [I] [zway] Adding job: Scheme Get
[2015-11-13 19:37:55.874] [D] [zway] Running wakeup handler for node 6
[2015-11-13 19:37:55.885] [D] [zway] SENDING (cb 0x7a): ( 01 0A 00 13 06 03 98 04 00 05 7A 00 )
[2015-11-13 19:37:55.886] [D] [zway] RECEIVED ACK
[2015-11-13 19:37:55.892] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-11-13 19:37:55.893] [D] [zway] SENT ACK
[2015-11-13 19:37:55.893] [D] [zway] Delivered to Z-Wave stack
[2015-11-13 19:37:55.908] [D] [zway] RECEIVED: ( 01 07 00 13 7A 00 00 02 93 )
[2015-11-13 19:37:55.908] [D] [zway] SENT ACK
[2015-11-13 19:37:55.908] [I] [zway] Job 0x13 (Scheme Get): Delivered
[2015-11-13 19:37:55.908] [D] [zway] SETDATA devices.6.data.lastPacketInfo.delivered = True
[2015-11-13 19:37:55.909] [D] [zway] SETDATA devices.6.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2015-11-13 19:37:55.909] [D] [zway] SETDATA devices.6.data.lastPacketInfo.deliveryTime = 15 (0x0000000f)
[2015-11-13 19:37:55.909] [D] [zway] SETDATA devices.6.data.lastPacketInfo = **********
[2015-11-13 19:37:55.910] [D] [zway] SendData Response with callback 0x7a received: received by recipient
[2015-11-13 19:37:55.910] [D] [zway] SETDATA devices.6.data.lastSend = 1272524 (0x00136acc)
[2015-11-13 19:37:55.911] [D] [zway] Job 0x13 (Scheme Get): success
[2015-11-13 19:37:55.911] [I] [zway] Removing job: Scheme Get
[2015-11-13 19:38:05.666] [I] [zway] Secure inclusion timeout
[2015-11-13 19:38:05.666] [D] [zway] SETDATA devices.6.instances.0.commandClasses.152.data.securityAbandoned = True
[2015-11-13 19:38:05.666] [I] [zway] Saving configuration data to config/zddx/e85f28ba-DevicesData.xml
I'm completely new to z-wave, so I don't know the impact of this, but something is obviously not as it should be.
Any thoughts?
Re: Secure inclusion timeout
Z-Way version?
geirgp
Post by geirgp »
PoltoS wrote:Z-Way version?
2.1.2-rc15
However, seems to not be a problem with z-way.
I did a factory reset of both units, that did the trick. Funny since they're both new.
