SSR303
Vmartinvega
SSR303
Post by Vmartinvega »
Hi
This module works ok in the z-wave network but when I manually modify the actuator state (I push ON button) the controller doesn't reflect this value and it continues as OFF value, so if someone presses manually some button there is not way to be notified. I don't know if this behavior is a known issue, it is a bug in the device firmware (SSR303) or a bug in the controller (Razberry). Anyone can help here?
Regards
