Amazon Echo API key or equivalent
jhmartin
Post by jhmartin »
https://github.com/armzilla/amazon-echo-ha-bridge looks to be a very easy way to integrate ZWay and Amazon Echo, but the tool only supports sending one URL for each on/off -- incompatible with the current login mechanics. Is there a way to supply login credentials along with the GET to the API?
Alternatively, that tool already has Vera integration where it queries the list of objects and creates the on/off url; would be nifty it could be made to do the same for zway.
Re: API key or equivalent
Yes, you can use HTTP Basic Auth or even make an anonymous user and allow him access without login/password.
Could you share with us Echo API? We are interested in making a special module for it by our forces,
libsysguy
Post by libsysguy »
I recently got this working via the http API for z-way using the docs found here: https://developer.amazon.com/public/sol ... rted-guide
Just published my src here: https://github.com/elliott-davis/echo-razberry
MadMAX
Post by MadMAX »
iam trying to run the alexa skill from libsysguy for the razberry but
i still get errors from the Lambda function.
Is there at the time a new skill i can use for alexa and a razberry board?
regards Max
