What libraries would you want to use with Z-Uno?
We need to port Arduino standard libraries to Z-Uno. This is a huge work, so we want first to make most required libraries first.
Please help us to choose most needed libraries. Below please add libs you are interested in and after we get some 20-30 libs, we will make a poll to vote for most usefull.
velib
Re: What libraries would you want to use with Z-Uno?
Post by velib »
Hi!
The I2C protocol usage is a must.
Dataworm
Post by Dataworm »
Support for the 1-Wire protocol would be nice. Also the protocol for sensors like DHT22 might be nice, but I think this is absolutely low priority. ;-)
romanstyler
Post by romanstyler »
I think DHT22 support will be really good feature. What do you think, is it possible to adopt current DHT22 in order to support Z-Uno?
We have internal DHT22 implementation, but we have not released it, since we want to improve it before. I think we can release it next week.
romanstyler
Super, sounds great! If it's possible i can connect to beta testing.
netclimber
Post by netclimber »
How about support for WS2812 and alike? There's this library: https://github.com/adafruit/Adafruit_NeoPixel
maddam
Post by maddam »
I2C a must
- MCP23017, I2C 16-bit serial expander
- SHT31, humidity and temperature sensor
- Arduino TimerOne
- SSD1306, 128x64 OLED display
- WS2812 - we will try in September. They require real time control of the chip, while Z-Uno also need to track RF transmission, so this will be hard.
- MCP23017 - already in C++ beta 2.0.4 - check this: https://github.com/Z-Wave-Me/Z-Uno-Core ... 17_I2CTest
- SHT31, humidity and temperature sensor - will consider
- Arduino TimerOne - Why do you need it? We have h/w timers in Z-Uno, but how do you want to use it?
- SSD1306, 128x64 OLED display - support of this display will be available next week in 2.0.5
maddam
Post by maddam »
PoltoS wrote: - SHT31, humidity and temperature sensor - will consider
You can add whole Sensirion SHTxx family. SHT31 is latest one. SHT will be big bonus as sharp factory calibrated hum and temp sensor. This one I want to use in my z-uno project over DHT.
Timer:
-I did not find in references/examples how to use z-uno internal h/w timers
-timerone can automatically set and control pwm on pin
-timerone can control/set your own interruptions and service routines
If there is similar functionality in z-uno you can skip this one, anyway this one library has no top priority among othes.
Nice MCP and OLED are available, thanks.
