v2.2.0 Mulilevel Switches not showing in automation
bcaroll
Post by bcaroll »
When I upgraded to v2.2.0 my light scene stopped working. When I look at the light scene I can only select one dimmer and that is a group. None of the dimmers that group is based on is show in the drop down. No other dimmer is shown either. The dimmers are working fine in the dashboards
When I looked further I saw that no Automation app can see my multilevel (except the one). I see nothing in the logs and has restarted several times.
SeaBii
Re: v2.2.0 Mulilevel Switches not showing in automation
Post by SeaBii »
I have the same issue. No multilevel sensors shows up when I try to configure e.g. a logical rule. But all my devices equipped with sensors sends their values (mostly temperatures in my case) and it is shown in the log. I tried to re-interview without any luck.
cdogg76
Post by cdogg76 »
I had the same problem and ended up downgrading to get my system working again.
Has anyone other than SeaBii and bcaroll also encountered this? Has anyone found a solution?
Thanks!
islipfd19
Post by islipfd19 »
Which modules are you encountering this issue in?
EdwardPayne
Post by EdwardPayne »
Yes all my binary switches are gone. They are not recognized as a switch anymore.
If I look in this menu, they are not listed with any type.
Expert -> Device -> Type Info
I don't know how to fix this but to downgrade.. Sad..
viper384
Post by viper384 »
islipfd19 wrote:Which modules are you encountering this issue in?
Lightscene. No multilevel devices are listed in the drop down.
I have the same exact issue as the original poster. The devices work fine outside of Zautomation.
After I upgraded the Zautomation instance worked, even though it looked broken when looking at the settings, it worked until I made a change, now it's broke. I tried down grading, by running the 'wget | bash' command with the older version and renaming /opt/z-way-server with older version but parts remained 2.2.0, for example my password never changed back. I decided to quit before I broke it completely, and 'wget | bash' back to 2.2.0. I have broken scenes now that need 'hacking' using workarounds that don't involve Zautomation.
viper384
Post by viper384 »
EdwardPayne wrote:Yes all my binary switches are gone. They are not recognized as a switch anymore.
Hope your issue got solved. But this may be a different issue. The bug the original poster refers to only affects dimmers with homeautomation, and the dimmers are present in Expert -> Device -> Type Info.
