[userModule] Base Module (Updated 2017/01/22)
maros
Post by maros »
This module provides many useful functions for other automation modules. It has no user facing functionality on its own.
If you want to use BaseModule for your own modules, just replace one line from the module initialisation
inherits(MyModule, BaseModule);
(instead of AutomationModule)
BaseModule helps module authors with these utilities:
  • Logging with prefixes instead of console.log and console.error
  • Timestamp of last real change in every vDev (metrics:modificationTime) - where metrics:level was actually changed
  • Events on real level change (modify:metrics:level)
  • Fetch presence states (via the Presence module)
  • Find devices based on criteria (tags, values, room, type ...)
  • Process devices from list of device IDs
  • Parse time
  • Compare time periods
  • Simplified timeout handling
You will need to install this module prior to installing my Thermostat control, Presence, ConditionSwitch, Motion Trigger, ... modules. Please make sure to instantiate this module.
Tested with Z-Way version v2.2.2
Bug/Issue tracker at https://github.com/maros/Zway-BaseModule/issues
Documentation at https://github.com/maros/Zway-BaseModul ... /README.md
Download at https://github.com/maros/Zway-BaseModule/releases
Installation can be done directly via git or via the the Zway App-Store.
Z-Way 2.2.4 on Raspi B | My Zway GitHub repos | Amazon Wishlist to support module development
masque
Re: [userModule] Base Module
Post by masque »
I'm very interested in the different modules you developed, based on this BaseModule. Unfortunately I can't get it installed correctly. The module appears as local module just fine. But as soon as I try to create an App I only get " 404 Not Found. Requested data does not exists". As I'm using Version 2.2.0 maybe this is the reason. As I just started with Z-Way I'm not sure where to check for further details. The z-way-Server log file does not say anything when I try to create the app.
Can you give me any hint where to look or do you have any idea why the base module isn't working on V2.2.0 ?
Masque
maros
Post by maros »
Either install it via the Z-Wave.me appstore. You'll need to add the 'k1_beta' app token to your app store config.
Otherwise if you install it manually, please make sure that is installed the /BaseModule and NOT in the /Zway-BaseModule folder
maros wrote: You'll need to add the 'k1_beta' app token to your app store config.
I do have an on-line apps tab in my 2.2.0 installation, but is completely empty. No place where I can store this token
masque
Post by masque »
This has to be put under "Management".
Like in the picture. After doing this, the packages are shown and you can download and install them.
You may also empty your Browser cache. I had issues with that from time to time as well.
Nevertheless the Problem with the BaseModule still exists in 2.2.0. I'm right on to downgrade to 2.1.1 to check if I can get it working there.
masque
Post by masque »
unfortunately no luck with v2.1.1 either.
This is a conmplete blank installation. I used the 2.1.2 razpberry img and downgraded to 2.1.1.
Then I manually installed the BaseModule as userModule.
I do see the BaseModule under Apps. I can create an app, which is listed as active. But I get the following errors in the log:
[2015-12-31 15:13:02.884] [I] [core] Instantiating module 10 from class BaseModule
[2015-12-31 15:13:02.889] [I] [core] --- Starting module Base Module
[2015-12-31 15:13:02.934] [I] [core] Notification: error (core): Cannot instantiate module: BaseModule: TypeError: undefined is not a function
[2015-12-31 15:13:03.019] [I] [core] TypeError: undefined is not a function
    at BaseModule.init (automation/userModules/BaseModule/index.js:35:57)
    at AutomationController.instantiateModule (automation/classes/AutomationController.js:308:22)
    at AutomationController.createInstance (automation/classes/AutomationController.js:504:14)
    at ZAutomationAPIWebRequest._.extend.createInstance (automation/ZAutomationAPIProvider.js:656:40)
    at ZAutomationAPIWebRequest.ZAutomationWebRequest.handleRequest (automation/WebserverRequestRouter.js:258:41)
    at automation/WebserverRequestRouter.js:32:35
    at WebServer.document_root (automation/Webserver.js:27:11)
maros
Post by maros »
masque wrote:unfortunately no luck with v2.1.1 either.
That is very strange. Looks like the getName method is missing from the AutomationModule base class. The latest master head from github should have a workaround/fix for this issue. Will publish this fix as soon as anybody can confirm that it works properly
masque wrote:This has to be put under "Management".
Thanks, I did not look there. (In earlier releases there was a non-functional space for it in the image that I posted above.
@Maros
maros wrote:Either install it via the Z-Wave.me appstore. You'll need to add the 'k1_beta' app token to your app store config.
How do users get their apps in the appstore? I haven't seen anything about this before.
masque
Post by masque »
maros wrote:Will publish this fix as soon as anybody can confirm that it works properly
Hi maros,
first of all hapy new year and many, many thanks for your fast support.
I checked out the newest version and now I can install and run the Base Module.
[2016-01-01 11:06:02.375] [I] [core] --- Starting module Base Module
[2016-01-01 11:06:02.413] [I] [core] [BaseModule-10] Init callbacks
From my side I can confirm that it is working now with v2.1.1
Unfortunately most of your other modules do show the same problem.
As well my productive v2.2.0 System still reports a 404 Error when creating the Base App, but I guess I will downgrade to v2.1.1 till V2.2.0 has become more stable. Seams that there are more issues that need to be fixed before v2.2.0 is usable in production.
regards
masque
