I`m searching a way to transmit ALL Events going over Z-Way EventBus by Script to another system.
Similar to this method:
viewtopic.php?t=20849&p=53783
...but i want not only special defined Z-Wave devices. I want to send ALL Events over UDP to another system. The way in the linked scripted works, but only for devices/variables i define in the code.
Is it possible to register/bind to ALL Events? Or could Z-Way start a JS-File at every event and in this JS-Code i need to have the complete event-text in a variable and send this variable-string over the UDP socket.
Or any other solution or idea?
The goal is, to have ALL Events from Z-Way in another system WITHOUT polling for events by "/ZWaveAPI/Data/**timestamp**". All events should be send directly in REAL-TIME.
Sorry for my bad english
Thanks in advance and kind regards,
Chris
