Problems in secure mode
bogr
Post by bogr »
when I finally managed to include my Aeon 6 (gen 5) multisensor (battery driven) I've discovered even more problems. Firstly the sensor never gets to sleep, wireless activity in expert UI says "Device is currently awake" and stays that way all the time. Checking the logs I see a lot of "Got usecure packet...":
[2016-01-05 18:29:27.061] [D] [zway] RECEIVED: ( 01 08 00 04 00 0A 02 84 07 78 )
[2016-01-05 18:29:27.061] [D] [zway] SENT ACK
[2016-01-05 18:29:27.061] [D] [zway] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2016-01-05 18:29:27.062] [W] [zway] Got unsecure packet from device 10, but Command Class 0x84 Wakeup is marked as secure. Ignoring packet.
[2016-01-05 18:30:00.299] [I] [core] ---  ZWayVDev_zway_10-0-48-1 performCommand processing: {"0":"update"}
[2016-01-05 18:30:00.300] [D] [zway] Job 0x13 (SensorBinary Get): removing duplicate
[2016-01-05 18:30:00.302] [I] [core] ---  ZWayVDev_zway_10-0-49-1 performCommand processing: {"0":"update"}
[2016-01-05 18:30:00.302] [I] [zway] Adding job: SensorMultilevel V5 Get
[2016-01-05 18:30:00.303] [I] [core] ---  ZWayVDev_zway_10-0-49-3 performCommand processing: {"0":"update"}
[2016-01-05 18:30:00.303] [D] [zway] Job 0x13 (SensorMultilevel V5 Get): removing duplicate
[2016-01-05 18:30:00.304] [I] [core] ---  ZWayVDev_zway_10-0-49-5 performCommand processing: {"0":"update"}
[2016-01-05 18:30:00.304] [I] [zway] Adding job: SensorMultilevel V5 Get
[2016-01-05 18:30:00.305] [I] [core] ---  ZWayVDev_zway_10-0-49-27 performCommand processing: {"0":"update"}
[2016-01-05 18:30:00.305] [I] [zway] Adding job: SensorMultilevel V5 Get
[2016-01-05 18:30:00.306] [I] [core] ---  ZWayVDev_zway_10-0-113-7-3-A performCommand processing: {"0":"update"}
[2016-01-05 18:30:00.307] [D] [zway] Job 0x13 (Alarm Get (v3)): removing duplicate
[2016-01-05 18:30:00.308] [I] [core] ---  ZWayVDev_zway_10-0-113-7-8-A performCommand processing: {"0":"update"}
[2016-01-05 18:30:00.308] [D] [zway] Job 0x13 (Alarm Get (v3)): removing duplicate
How come the it gets "unsecure packets"?
I've also tried to do some config changes, and then waking up the sensor, but the changes never get saved.
The job queue looks like:
n	U	W	S	E	D 	Ack	Resp	Cbk	Timeout 	NodeId	Description	Progress	Buffer
0		W	S			-	-	-	0.20	10	SensorBinary Get		a 2 30 2 5
0		W	S			-	-	-	0.20	10	SensorMultilevel V5 Get		a 4 31 4 1 0 5
0		W	S			-	-	-	0.20	10	SensorMultilevel V5 Get		a 4 31 4 3 8 5
0		W	S			-	-	-	0.20	10	SensorMultilevel V5 Get		a 4 31 4 5 0 5
0		W	S			-	-	-	0.20	10	SensorMultilevel V5 Get		a 4 31 4 1b 0 5
1		W				-	-	-	0.20	10	Nonce Get	Not delivered to recipient	a 2 98 40 5
0		W	S			-	-	-	0.20	10	Alarm Get (v3)		a 5 71 4 0 7 0 5
1		W				-	-	-	0.20	10	Nonce Report	Not delivered to recipient	a a 98 80 f0 92 30 56 77 72 20 a0 5
0			S			-	-	-	0.20	10	SensorBinary Get		a 2 30 2 5
0			S			-	-	-	0.20	10	SensorMultilevel V5 Get		a 4 31 4 1 0 5
0			S			-	-	-	0.20	10	SensorMultilevel V5 Get		a 4 31 4 3 8 5
0			S			-	-	-	0.20	10	SensorMultilevel V5 Get		a 4 31 4 5 0 5
0			S			-	-	-	0.20	10	SensorMultilevel V5 Get		a 4 31 4 1b 0 5
0			S			-	-	-	0.20	10	Alarm Get (v3)		a 5 71 4 0 7 0 5
Queue length: 14
Any ideas? Having the device in unsecure mode, everything works as "it should". Are there any differences when running in secure mode?
Cheers,
Bo
Re: Problems in secure mode
This is because the device reports Wakeup CC as secure (this is not the case, as it sends unsecure Notifications). Just do
/JS/Run/zway.devices[10].Wakeup.data.security=false
bogr
Post by bogr »
Fantastic! No more "Got unsecure packet" in the logs and the device goes to sleep :D. Thanx a lot!
eppa
Post by eppa »
I have the same problem, but where do you write the code?
