I follow the directions here:
http://www.homeautomationforgeeks.com/o ... wave.shtml
Which say to install zwave using this:
wget -q -O - http://razberry.z-wave.me/install | sudo bash
(it puts a folder "z-way-server" in /opt and inside that folder is the "green" "z-way-server" file)
Reboot, then access the zwave server here:
myip:8083
But that doesn't bring up the UI.
Also when I go to stop the zwave server by doing this:
sudo service z-way-server stop
I get this error:
Stopping z-way-server: rm: cannot remove `/var/run/z-way-server.pid': No such file or directory
thanks for all the help
Travis
Installation Problem - Zwave
Re: Installation Problem - Zwave
Which Z-Wave controller do you use? RaZberry or Zwave.me UZB1
Check if the server has started at all, by listing the processes. Sounds like it's not even started and then you'll of course not see the UI and not be able to stop it. Maybe you'll see some errors in the log, so check that as well.
Edit: I ran "ps axg" and didn't see anything zwave related.
Razberry module
Yea i'm pretty sure the process is not starting, but I'm not sure how to list all processes. I will research that.
So assuming the process is not starting, how would I go about starting it?
When I go into the zwave installation folder in /opt/z-way-server/ and run "sudo ./z-way-server" I get this error.
I attached the screenshot showing the error.
Thanks for all the help.
Razberry module
- Screenshot_2016-01-16-14-02-24.png (315.42 KiB) Viewed 11671 times
try
if this doesn't work try
to see what the console says. I had some problems with a shared object library and had to make a soft link to another version of the same .so, but I think it was libarchive.so.
/etc/init.d/z-way-server startCode: Select all
LD_LIBRARY_PATH=libs ./z-way-serverRe: Installation Problem - Zwave
yes thank you, that did launch the server and I can control my devices.
