Razberry Fibaro custom module
khafeez
Post by khafeez »
I have razberry, Fibaro wall switch and a temperature sensor. I am reading the values of temperature sensor and i want to handle the status of the switch (which is connected to a fan). So if the temperature is below some value the switch turns on.
Can anyone tell me how to do that please.
Re: Razberry Fibaro custom module
Use App Logical rule
khafeez
Post by khafeez »
Can you please explain. Im a newbie in Home automation and z wave development.
remoticz
Post by remoticz »
Go to tool icon in top right corner, and select Apps. Next do select tab Local APPs and next All Apps
Below there you'll find Logical rule. Under Condition select multilevel, and next pick your temperature sensor.
Then define your switch under the Actions section
v2.1.1 raspi2
