yesterday I included a Room Thermostat from Danfoss into Z-Way. The interview was successfull except for 2 Command Classes: ThermostatSetPoint and Version. This device supports the ThermostatSetPoint V3 and if I look deep into the traces it seems there is a misinterpretation of the values delivered by the Danfoss RS.
Attached the following:
- Screenshot from Expert UI about interview
- Log from Z-Wave debug log (lines from 118 to 121 is where I suspect the issue is)
- link to the Specification of the Danfoss RS: http://products.z-wavealliance.org/products/1062
Thanks and regards
Possible bug with CC ThermostatSetpoint v3
aleconakad
- zlog.zip
- log (check lines 118 - 121)
- (3.01 KiB) Downloaded 438 times
- screenshot about interview
- 2016-01-21 10_50_25-Z-Wave Expert UI.png (76.73 KiB) Viewed 6506 times
Re: Possible bug with CC ThermostatSetpoint v3
I get exactly the same problem.
Have you found a solution or workaround?
