Wrong description for Qubino Flush 2 Relay
Just noticed that the expert gui (Configuration tab) lists a parameter 100 ("Nº 100 - Enable / Disable Endpoint I2 or select Notification Type and Event"), but according to the spec there is no parameter 100. Seem to be a glitch in ZDDX/791-0159-0002-0051-03-04-05-01-01.xml? Can't attach the pdf - "Qubino_Flush-2-relays-PLUS-user-manual_eng_V1.3.pdf" as reference.
Re: Wrong description for Qubino Flush 2 Relay
BTW, I'll send this to Qubino and see what they have to say, since it't not really a case for z-way.
It's now fixed by the "peppers"
