QUBINO ZMNHBD1
guigui51
QUBINO ZMNHBD1
Post by guigui51 »
Good morning,
I have a raspberry pi with the razberry GPIO board.
I'm trying to manage this device :
Micromodule commutateur 2 relais et consomètre Z-Wave+ ZMNHBD1
http://www.domadoo.fr/fr/peripheriques/ ... results=23
But I did'nt sucess.
With z-waveme the device is reconized with the OLD UI, but I can't manage the two relays, when I switch off, both of them are switched off.
Thanks for your help
bogr
Re: QUBINO ZMNHBD1
Post by bogr »
this device exposes 3 interfaces - one to switch Q1, second for Q2 and third to switch _both_ at the same time. If you look in the GUI you should see tree switches, e.g. "Switch ID-0", "Switch ID-1" and "Switch ID-2" (where ID=number). The "-0" operates both lines. Don't know what you mean by the OLD UI, but use the latest and it should work (except for some problems with associations).
rpochet
Re: QUBINO ZMNHBD1
Post by rpochet »
New to Z-Wave and RaZberry, I also have problem to manage QUBINO ZMNHBD1. In fact, after some include/exclude, I got it working (3 instances: 12.0, 12.1, 12.2 in my case). But after a server restart, everything is corrupted: only 1 instance 12, rooms do not contain device... After an interview (require again to select a device description...), i got 3 instances again (and rooms are OK).
PS: i still have problem to associate a switch to one relay, the UI only provides 12 as device, not 12.0, 12.1, 12.2
Sorry but I have no real solution
rpochet
Jeedom on RPI 3
Re: QUBINO ZMNHBD1
This is because device have not passed interview. Do Force Interview to interview it again as much as possible and then gracefully stop Z-Way to let it save data. Then it will work
Mansica
Re: QUBINO ZMNHBD1
Post by Mansica »
I have the same problem and doing as PoltoS is suggesting is not helping.
Re: QUBINO ZMNHBD1
How do you stop Z-Way?
Mansica
Re: QUBINO ZMNHBD1
Post by Mansica »
/etc/init.d/z-way-server stop
Re: QUBINO ZMNHBD1
Can you show log or provide remote support access?
Mansica
Re: QUBINO ZMNHBD1
Post by Mansica »
What exactly do you want to see from the log? It is _very_ verbose.
I have attached a log which seems to cover from when the server is stopped to when all devices should be up. I have four devices. 2, 7, 10 and 11. 2 is a door sensor and is working perfect. The other three are qubino relays.
z-way-server.zip
z-way-server.log
(34.92 KiB) Downloaded 420 times
