Hi everyone
all my z-wave products are from US and run on 908 Mhz.
however my razberry are from EU so i believe it set for that frequency.
when i read the manual and look in the expert interface it looks like i can change the frequency. but i have not succeed the frequency by click any of the frequency on the expert panel. it always says "Current frequency: unknown", and i cant find any of my z-wave sensors.
Can i change the frequency ? or did i misunderstand the manual and need to buy a new one in US.
PS please turn on the search function on the forum so we don't have to ask the same question over and over again
Kind regards Håkan Mattsson
how to change frequency in 2.2 ?
- freq.png (17.89 KiB) Viewed 7317 times
Re: how to change frequency in 2.2 ?
I had the same issue before but after upgrade of firmware and bootloader the changing frequency works.
Check you firmware under Network/Controller info and your firmware is listed under.
Serial API Version: 05.04
If lower go to http://your_ip:8083/expert/#/uzb and update firmware.
