Device interview stage is not complete
larry
Post by larry »
in my system so I have a Kamstrup slave module in my RPI everything work
I'll put up new RPI and new card so I get Device interview stage is not complete slave MODL does not seem like it should
How can get it to work the new one?
Someone who can help me? some I move from RPI 1 of config of paragraph 2 ??
greatly appreciate if I can get help for this?
golaonline
Re: Device interview stage is not complete
Post by golaonline »
Have you tried, Force Interview option. I am a new z-way user, but in my case if some times device needs to be really close to RPi to get the interview completed successfully, otherwise I have seen it takes some time and redoing.
Hope this helps.
larry
Post by larry »
Anybody have any suggestions?
there is an xml config I move over from old to new?
larry
Post by larry »
i use that commmand and i get Interview complete
1.:8083/ZWaveAPI/Run/devices[3].instances[1].commandClasses[0x72].data.interviewDone.value=true
2. 8083/ZWaveAPI/Run/devices[6].instances[2].commandClasses[0x86].data.interviewDone.value=true
3. 8083/ZWaveAPI/Run/devices[6].instances[3].commandClasses[0x86].data.interviewDone.value=true
4. 8083/ZWaveAPI/Run/devices[6].instances[4].commandClasses[0x86].data.interviewDone.value=true
fines any way that I save this? so I do not have to create a script that does this for me.
