Not able to access Expert UI from Port 8084
Black Cat
Post by Black Cat »
First time poster and trying to get my head around this system.
After I upgraded to V2.2.1 I'm unable to access the Expert UI from Port 8084, all I get is the following message.
Webif is switched off. You can switch it on from Z-Way UI or box shell
I have not been able to find where I can switch it on, can anyone help please?
DomotikQuebec
Re: Not able to access Expert UI from Port 8084
Post by DomotikQuebec »
Log in as admin on port 8083,
Go to your account settings and there is a checkbox to enable the expert UI
Good luck ;-)
Mario Gravel
Domotik Quebec
Click the tools icon in the top right corner, select Devices from Dropdown menu and you get the link:
Black Cat
Post by Black Cat »
Nup,
All I get from the devices menu is:
What Z-Wave controller do you have? If so do you have the Zwave module enabled on the correct port?
Black Cat
Post by Black Cat »
It's a Popp Hub.
Sorry, I don't know that rig. Better send this question to the store where you bought this, or to Popp directly. They are primarily responsible for proper functioning
Black Cat
Post by Black Cat »
That's strange, as this only started after I upgraded to the latest firmware version.
As far as I can see there is no difference in the Popp as it's a RP2 with the Z daughter board!
It looks as if your Z-Wave is not properly running. I your Z-Wave app active"? what port?
DomotikQuebec
OH ! I got the same thing but I didn't got it correctly the first time...
1: This is not the Expert UI but the "mongoose" interface. Expert UI is on port 8083 and the Webif is on 8084 (right ?)
2: I got it event after updating firmware
3: I thought that I may have disabled some app so I reinstall my whole Raspberry + Z-Way but no luck !
Mario Gravel
Domotik Quebec
