razberry scenes
marko4791
razberry scenes
Post by marko4791 »
I want to ask you, what is the easiest way for creating scenes. Is there a program to do it ? it works in Expert UI ?or I have to programing using JSON API? I want to create only a simple relation between motion sensor and switche.
Thanks !
Re: razberry scenes
Use Expert UI
Menu:Configuration
Tab:Association
marko4791
Re: razberry scenes
Post by marko4791 »
Yes i used, but it didnt work. I have Zipato switch modul and Fibaro motion sensor. I set association between them, but nothing has happened.
Re: razberry scenes
Has the interview of both devices been completed?
(Also you can search this forum with the terms: association motion)
marko4791
Re: razberry scenes
Post by marko4791 »
Yes interview is complete. Can you tell me how to set up the correctly associations, it is possible that I am doing them wrong. Or do you know about any manuals?
Re: razberry scenes
This image shows how I made the association from a Zwave.me WallC-S controller(ControllerSlkLA) to a binary switch (Vliering). The first association is with the ZWay controller, so it does get signalled by the wall controller. (click image to see full size)
Unfortunately there is virtually no simple user instruction.
marko4791
Re: razberry scenes
Post by marko4791 »
i send images setting association sensor and switch. It is correct ? I dont know, but I want when sensor detects motion turn on the switch.
Bez názvu1.png (31.78 KiB) Viewed 13919 times
Bez názvu.png (29.38 KiB) Viewed 13919 times
Re: razberry scenes
What you do seems correct to me. But I must admit I have very little knowledge/Experience with associations
marko4791
Re: razberry scenes
Post by marko4791 »
OK, but how I can create a completely smart home by raZberry? scenes and the like. Only through API programming?
Re: razberry scenes
I must leave that problem of association to the forum owners. In principle it should work.
I can't answer your question
Since I do not know what you mean by it. What must be made smart?
There are some 50 Apps now for ZWay that can help you make more or less intelligent solutions.
