Is reorganization broken?
Plainsane
Post by Plainsane »
System was turning things on and off no problem. 2 days ago did a backup of the zwave controller configuration, hard reset of the controller and restore.
Now a hand full of devices timeout constantly and a reorganization does,not,correct the situation. To change the routing table in a manner to reach these devices at the extremities. Like I said, this worked flawlessly until the reset so I have to point to a simp,e routing table. Anybody have this issue? Can anybody confirm?
Re: Is reorganization broken?
Reoranization is not really working, but you should go in routing table instead and press Update on all devices. This works perfectly
Plainsane
Post by Plainsane »
But it is not, that's another problem
Plainsane
Post by Plainsane »
I can't update the devices at the edges, and now my routing table only shows green for the top row, only controller can talk to each device.
Is there an older version where this worked? Aka, is the routing table on the controller and can I use an older version to reconstruct the table?
Plainsane
Post by Plainsane »
Ok 2.2.2 rc3 at least corrects manually updating the routing table. 2.2.1 did,not
