i have a problem after install new version (i have razberry....today i install new raspbian on raspberry and then install newest version of zwave)
any tips ?
problem with new version v2.2.2
- obr3.png (21.1 KiB) Viewed 22183 times
- obr2.png (52.12 KiB) Viewed 22183 times
- obr1.png (36.5 KiB) Viewed 22183 times
Re: problem with new version v2.2.2
The tips I got are give more information about which type of Raspberry Pi your using and try installing 2.2.1 version. I dunno what happened on my Pi, my SD card was full and cannot even get an old nor new version up and running. I've read the newer version of the Raspberry Pi has some issues. Without additional (extensive) information none can give you advice on what to do
-> A fellow Z-way user running a network of 50+ devices
I had the same problem with raspbian jessie. So i switched back tho wheezy and everything was ok.
I did this because i did a fresh install anyway...
Just for the record: Which Jessie release? ( Month/Year) (Full version/Lite)cyberhofi wrote:I had the same problem with raspbian jessie.
Hi all
i'm facing the same issue with: Raspbian Jessie,Full desktop image based on Debian Jessie
Version: May 2016 - Release date: 2016-05-10 - Kernel version: 4.4
installed on Raspberry Pi 2 & Razberry.
no way to start the controller, it seems to be a communication problem.
any help will be appreciate, Thanks
I had similar problems with Jessie. Have a look at http://raspberrypi.stackexchange.com/qu ... ian-jessie.
The two steps I needed were to disable the serial port login through raspi-config and then to enable the serial port by editing /boot/config.txt and setting enable_uart=1.
I have the same problem.cyberhofi wrote:I had the same problem with raspbian jessie. So i switched back tho wheezy and everything was ok.
Can you please tell me the link to wheezy version to download which is working with z-wave module. I have tried a couple of them from http://downloads.raspberrypi.org/raspbian/images/ . but none of them is working for me
I had similar problem yesterday and I solved shutdown -h, then power cycle your box (not just reboot, but unplug power for few seconds!).
I was having the same problem but the i switched to z-wave version 2.2.1 now there is this just error unable to load data from server.
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
P.S If someone has link to wheezy version of Raspbian please tell.
I have the same problem with version 2.2.2 on jessie. Version 2.0.0 is working a bit but also not correct. Running it on Rasperry pi 2 4.4.13-V7+. Serial switch of and try enable_uart=1 and #enable_uart=0 (so disabled, with this version 2.0.0) is working. Do I need to do more?
