Defective RaZberry?
Equinox
Defective RaZberry?
Post by Equinox »
I have a new Raspi 2 and a new RaZberry (Z-Wave plus).
After installation, the communication with the RaZberry does not work.
Error in log-file:
[2016-04-30 23:19:56.195] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2016-04-30 23:19:56.407] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2016-04-30 23:19:56.407] [W] [zway] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
[2016-04-30 23:19:56.407] [D] [zway] Job 0x07 (Get controller info and supported function classes): fail
[2016-04-30 23:19:56.407] [C] [zway] Get Serial API Capabilities returned zero.
[2016-04-30 23:19:56.408] [I] [zway] Removing job: Get controller info and supported function classes
[2016-04-30 23:19:56.418] [D] [zway] Worker thread exit point
[2016-04-30 23:19:56.418] [D] [zway] Worker thread successfully finished
[2016-04-30 23:19:56.419] [E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
[2016-04-30 23:19:56.450] [I] [core] Notification: critical (z-wave): Cannot start Z-Wave binding: Error: Bad data - communication failed
After powering up the Raspi, the LEDs of the RaZberry blink once and then go off (and stay off). Shouldn't the red LED be on (at least it is like that with my old RaZberry (without "plus")).
My questions:
1. Any idea how to solve that problem?
2. How can I check whether the RaZberry is OK?
3. How can I check whether the Raspi's GPIO is OK?
Many thanks!
Equinox
Equinox
Re: Defective RaZberry?
Post by Equinox »
in the meantime, I found out that the RaZberry is OK. So, it must be a faulty installation or defective GPIO-pins of the Raspberry.
How can I ceck whether the Raspi's GPIO is working correctly?
Thanks.
Equinox
oriharel
Post by oriharel »
Did you solve your problem? how?
@Equinox
connect TX to RX and use minicom to see if you see everything you are sending
