Im searching for a way to send command to my Hikvision camera. Purpose is to start camera alarm when PIR sensor detects motion.
Post regarding hikvision command: https://www.ipcamtalk.com/showthread.ph ... -PTZ/page2
Is there any app for razberry that can send PUT/POST/CURL? Or an app where to customly code your own scene with for example JS?
thanks in advance
Send PUT/POST/CURL on sensor trigger
Re: Send PUT/POST/CURL on sensor trigger
I would need the same for the Philips Hue. I did a hacky integration via curl and "Code Device" but I would have prefered a clean solution. My request remained unanswered as well: https://forum.z-wave.me/viewtopic.php?f=3422&t=23375
