Massive issue with 2.2.2 and 05.04 firmware
codypchristian
Post by codypchristian »
I've been running 2.2.1 since it came out with "Serial API Version: 05.00" firmware. However 2 days ago I upgraded to 2.2.2 and then upgraded firmware to "Serial API Version: 05.04" and now nothing appears to be working device wise. I get "Device appears to be dead" on all 20+ devices now. I tried going back to 2.2.1 and same results. Any ideas? My only thought is the 5.04 upgrade caused this. Anyway to go back? I can't even locate that firmware in git anywhere. Thank you.
Side note: I also attempted to use OpenHAB2 as well and exact same issues so I really do think its a problem with the firmware on the daughter board chip.
Controller Data:
/: None (11:54)
    nodeId: 1 (11:54)
    homeId: -190074062 (11:54)
    SUCNodeId: 1 (11:54)
    isPrimary: true (11:54)
    isInOthersNetwork: false (11:54)
    isRealPrimary: true (11:54)
    isSUC: true (11:54)
    SISPresent: true (11:54)
    libType: Static Controller (11:54)
    SDK: 6.51.06 (11:54)
    ZWlibMajor: 4 (11:54)
    ZWlibMinor: 5 (11:54)
    ZWLib: 1 (11:54)
    ZWVersion: 5 (11:54)
    ZWaveChip: ZW0500 (11:54)
    APIVersion: 05.04 (11:54)
    manufacturerId: 327 (11:54)
    vendor: RaZberry by Z-Wave.Me (11:54)
    manufacturerProductType: 1024 (11:54)
    manufacturerProductId: 2 (11:54)
    capabilities: 2,3,4,5,6,7,8,9,10,16,17,18,19,20,21,22,23,24,28,32,33,34,35,36,39,40,41,42,43,44,45,65,66,68,69,70,71,72,73,74,75,76,77,80,81,83,84,85,86,87,94,96,97,98,99,102,103,120,128,144,146,147,152,180,182,183,184,185,186,189,190,191,210,211,212,239,242,244,245 (11:54)
    controllerState: 0 (12:29)
    nonManagmentJobs: 0 (11:54)
    lastIncludedDevice: None (12:25)
    lastExcludedDevice: None (12:25)
    secureInclusion: true (12:22)
    oldSerialAPIAckTimeout10ms: 10 (11:54)
    oldSerialAPIByteTimeout10ms: 10 (11:54)
    curSerialAPIAckTimeout10ms: 10 (11:54)
    curSerialAPIByteTimeout10ms: 10 (11:54)
    countJobs: false (11:54)
    memoryGetAddress: None (11:54)
    memoryGetData: None (11:54)
    functionClasses: 2,3,4,5,6,7,8,18,19,21,22,23,32,33,34,35,36,39,41,42,43,44,45,65,66,68,70,71,72,73,74,75,76,77,80,81,82,83,84,85,86,87,96,97,98,99,128,186,190,210,211,242,243,244,245 (11:54)
    functionClassesNames: SerialAPIGetInitData,SerialAPIApplicationNodeInformation,ApplicationCommandHandler,GetControllerCapabilities,SerialAPISetTimeouts,GetSerialAPICapabilities,SerialAPISoftReset,SendNodeInformation,SendData,GetVersion,SendDataAbort,RFPowerLevelSet,GetHomeId,MemoryGetByte,MemoryPutByte,MemoryGetBuffer,MemoryPutBuffer,FlashAutoProgSet,NVMGetId,NVMExtReadLongBuffer,NVMExtWriteLongBuffer,NVMExtReadLongByte,NVMExtWriteLongByte,GetNodeProtocolInformation,SetDefault,ReplicationReceiveComplete,AssignReturnRoute,DeleteReturnRoute,RequestNodeNeighbourUpdate,ApplicationNodeUpdate,AddNodeToNetwork,RemoveNodeFromNetwork,CreateNewPrimary,ControllerChange,SetLearnMode,AssignSUCReturnRoute,EnableSUC,RequestNetworkUpdate,SetSUCNodeId,DeleteSUCReturnRoute,GetSUCNodeId,SendSUCNodeId,RequestNodeInformation,RemoveFailedNode,IsFailedNode,ReplaceFailedNode,GetRoutingTableLine,RFPowerLevelGet,SendTestFrame,WatchDogStart,WatchDogStop,ZMEFreqChange,ZMERestore,ZMEBootloaderFlash,ZMECapabilities (11:54)
    softwareRevisionVersion: v2.2.1 (11:54)
    softwareRevisionId: a52a38822b6872f5b9fab0903b30ab65a2c70605 (11:54)
    softwareRevisionDate: 2016-02-18 17:41:33 +0300 (11:54)
    uuid: 2a8c99c9d6c0290da77cf2a352488b1d (11:54)
    caps: 0,0,255,5 (11:54)
    frequency: US (12:37)
Thanks, Cody
codypchristian
Re: Massive issue with 2.2.2 and 05.04 firmware
I've rebooted again and now all I get is that it can't find the daughterboard. Man this firmware has really screwed stuff up!
[2016-06-26 13:18:19.651] [C] [i/o] Failed to open device /dev/ttyAMA0: No such file or directory
Both zbw_connect and z-way-server were running and haven't been touched, all I did was restart. Now zbw_connect is still up but z-way-server dies because it can't connect to the device.
Ideas?
Thanks, Cody
Upgrading to new f/w can not affect AMA0, since it is h/w port on your Pi. So, if AMA0 is missing, means your kernel parameters were screwed up. What is your OS?
codypchristian
Hey, the only change was upgrading the firmware. The OS was not modified or upgraded.
Currently it is:
Linux raspberrypi 4.4.13-v7+ #894 SMP Mon Jun 13 13:13:27 BST 2016 armv7l GNU/Linux
Raspbian GNU/Linux 8 (jessie)
Thanks, Cody
Solved?
vosmont
Post by vosmont »
I was on 2.2.3 and try to upgrade with
reboot
now I've got the same problem :
Some infos on my Raspberry B:
pi@openLuup:~ $ uname -a
Linux openLuup 4.1.18+ #846 Thu Feb 25 14:11:56 GMT 2016 armv6l GNU/Linux
pi@openLuup:~ $ cat /proc/version
Linux version 4.1.18+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #846 Thu Feb 25 14:11:56 GMT 2016
pi@openLuup:~ $ cat /etc/issue
Raspbian GNU/Linux 8 \n \l
pi@openLuup:~ $ cat /etc/debian_version
8.0
pi@openLuup:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
NAME="Raspbian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
dmesg :
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.1.18+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #846 Thu Feb 25 14:11:56 GMT 2016
[    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[    0.000000] Machine model: Raspberry Pi Model B Rev 2
[    0.000000] cma: Reserved 8 MiB at 0x1b400000
[    0.000000] Memory policy: Data cache writeback
[    0.000000] On node 0 totalpages: 114688
[    0.000000] free_area_init_node: node 0, pgdat c0839994, node_mem_map db010000
[    0.000000]   Normal zone: 1008 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 114688 pages, LIFO batch:31
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 113680
[    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708.boardrev=0xe bcm2708.serial=0x3f4c4a29 smsc95xx.macaddr=B8:27:EB:4C:4A:29 bcm2708_fb.fbswap=1 bcm2708.uart_clock=3000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 436836K/458752K available (5792K kernel code, 488K rwdata, 1788K rodata, 352K init, 720K bss, 13724K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xdc800000 - 0xff000000   ( 552 MB)
    lowmem  : 0xc0000000 - 0xdc000000   ( 448 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .text : 0xc0008000 - 0xc076f1f0   (7581 kB)
      .init : 0xc0770000 - 0xc07c8000   ( 352 kB)
      .data : 0xc07c8000 - 0xc0842260   ( 489 kB)
       .bss : 0xc0842260 - 0xc08f63e0   ( 721 kB)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS:522
[    0.000000] clocksource stc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    0.000015] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[    0.000055] Switching to timer-based delay loop, resolution 1000ns
[    0.000342] Console: colour dummy device 80x30
[    0.001249] console [tty1] enabled
[    0.001306] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000)
[    0.001392] pid_max: default: 32768 minimum: 301
[    0.001768] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001839] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.002896] Initializing cgroup subsys blkio
[    0.002991] Initializing cgroup subsys memory
[    0.003061] Initializing cgroup subsys devices
[    0.003122] Initializing cgroup subsys freezer
[    0.003182] Initializing cgroup subsys net_cls
[    0.003302] CPU: Testing write buffer coherency: ok
[    0.003420] ftrace: allocating 19747 entries in 58 pages
[    0.107952] Setting up static identity map for 0x81c0 - 0x81f8
[    0.110127] devtmpfs: initialized
[    0.120836] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    0.121291] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.123292] pinctrl core: initialized pinctrl subsystem
[    0.124199] NET: Registered protocol family 16
[    0.129628] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[    0.131057] bcm2708.uart_clock = 3000000
[    0.135949] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.136026] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.136233] Serial: AMBA PL011 UART driver
[    0.136532] 20201000.uart: ttyAMA0 at MMIO 0x20201000 (irq = 83, base_baud = 0) is a PL011 rev2
[    0.501688] console [ttyAMA0] enabled
@vosmont This is because you use some custom openLuup distro. Make sure how serial port is accessed there.
@pepeEL please don't write in unrelated threads about your problem
