Set Parameters from device
Wikibear
Post by Wikibear »
Hello together,
i use a Fibaro Motion Sensor with 2.7 Firmware. The manual say that define parameters are available:
http://manuals.fibaro.com/motion-sensor/
My goal is to increase the illuminating sensor with sending data. Default is 0 no sending data. Thats bad.
I found a link in web that makes Temp more times:
wget http://192.168.10.xxx:8083/ZWaveAPI/Run ... (64,600,2)
So i dont know what this parameters mean!
How can i set parameters for illumination as fibaro say in manual?
Greatings from the noob
Wikibear
Re: Set Parameters from device
Post by Wikibear »
Found solution! That's totally hard for a noob like me. So i understand after long testing reading and compare my knowings.
This webpage here:
has a list of all advanced parameters. The hint is here that 1,2,3 counting are not a normal counting this are for parameters. So my needings where here 40. You can set this via configuration of device in expert ui or you can do this via API:
http://rasip:8083/ZWaveAPI/Run/devices[ ... alue,byte)
I do it via browser.
http://rasip:8083/ZWaveAPI/Run/devices[ ... et(40,5,2)
And now i get every time lux change an update with fibaro multi sensor. You can/must do the same with temp.
Our doc describes pretty well these command. Indeed you can use these API calls to set params wrongly descirbed in device description. You can also use Expert Commands tab to send fill user friendly form to send same commands
