[BUG] ReferenceError http header 500
Wikibear
Post by Wikibear »
I try to access via curl like your faq told me on your website:
http://192.168.0.5:8083/ZWaveAPI/Run/de ... y_3-0-49-3
I get: "ReferenceError: ZWayVDev_zway_3 is not defined"
The header response is 500 Internal Server Error.
How can i solve this?
Greatings from the noob
añep
Re: [BUG] ReferenceError http header 500
Post by añep »
Wikibear wrote:I try to access via curl like your faq told me on your website:
It's possible you needs first login:
LOGIN:
curl -i -H "Accept: application/json" -H "Content-Type: application/json" -X POST -d '{"form":true,"login":"youruserlogin","password":"yourpassword.","keepme":false,"default_ui":1}' http://192.168.0.5:8083/ZAutomation/api/v1/login -c cookie.txt
YOUR REQUEST:
curl -s -LN --globoff http://192.168.0.5:8083/ZWaveAPI/Run/devices/ZWayVDev_zway_3-0-49-3 -b cookie.txt
Wikibear
Post by Wikibear »
But if you are not logged in you get an error with login. Not 500 this is an internal server error.
añep
Post by añep »
Wikibear wrote:But if you are not logged in you get an error with login. Not 500 this is an internal server error.
You try:
http://192.168.0.5:8083/ZAutomation/api/v1/devices/ZWayVDev_zway_3-0-49-3
Wikibear
Post by Wikibear »
Jep, then there is truly a bug. Than i must get an error not Logged In not an 500 message. ;) If i'm not logged in i get 401 error normally.
The problem was that /ZWaveAPI/Run/devices/ZWayVDev_zway_3-0-49-3 was a worng URL. Even logged it it is worng.
As stated above, use /ZAutomation/api/v1/devices/ZWayVDev_zway_3-0-49-3
