Only Issues and Bugs
Wikibear
Post by Wikibear »
So Guys... I'm totally exaust. I have never get so many problems as with RaZberry!
First only trouble with Fibaro Multi Sensor and now my Thermostates doesn't work also as expected. I sit here day for day and nothing work well!
I have a Device 1 but no Device 1 in my Log but not in my Device List. Seems to be Fibaro Multi Sensor also. My Danfoss Thermostates are Included but seems to be dont wake up. Now the show E5! The distance between all devices to the controller are less then 5m!!! What in the hack going on here? If one device work the other doesn't work or what?
Sorry i'm totally angry. I look all the time that i make faults. Yes maybe, but more and more i think RaZberry is Trashbaby! :evil:
At this point i updated to v2.2.3 today. But nothing change here.
Greatings from the noob
Re: Only Issues and Bugs
My sympathies. I have gone through the same agonies with the older version of Danfoss DLC. I decided to change to Eurotronic StellaZ. I do have 11 of these devices. The advantage of the Stella is that it doesn't have a brain from itself. So if you change the temperature It actually changes the setting at the next wake-up. With DLC at times it took up to 2 hours before I could measure a change.
The only StellaZ drawback for me is that ZWay still does not support N-State switch devices to set the proper mode.
PS: I found my system to become much more stable after I changed the configuration to write the logfiles to a separate USB-stick on my RaspberryPi. (See this Recipe) under Write log files to USB-stick
Wikibear
Post by Wikibear »
So i restarted with v2.2.3 totally. Complete Reset all devices to factory reset. At the moment thats not a big problem i have only three devices yet. I do this cause one of my Danfoss was out of network or not. The other one seems to be working. And then lost communication, too. My Fibaro Mutation Sensor (Motion) works also more then bad. I think i have an complete network issue. After v2.2.3 update i start to reset all to factory.
Then i start one by one with Danfoss first. The first Danfoss was included without any problems. I was happy that this work so fast and good. SmartHome Ui set hardware configuration without expert ui and i can setup the device with all configuration its available. Nice! So then i started with the second one. And this doesn't work. I unmounted the device and no inclusion works. (Remember that i set all devices back to factory mode) Then i start factory reset again. With the device in my hand and a distance of 2m from controller i can include it into the network. Mounted on the heater the connection stay without any problems. So, this shows you if you don't have a clue what you must do you will go down in hell... That shows me now that my network is pretty good and devices are working. Danfoss has many different manuals. That's amazing. You must read all of them to understand how this works. :) There is a special menu in it that you can check network range and you can setup the radiator size to the room. Small radiator big room e.g. I started to read normal manual within the package i can't find this kind of information. After searching manuals via google you find interesting things. One thing more that this system go them self in to a learn mode for 1-7 days. My package manual don't have those kind of lines written down in it. This drives me crazy as well. The thermostat's know if you open windows cause of rapid temperature loss. The stop heating by itself! Then you have special climate settings in expert ui you don't finde in smarthome ui. Why? Also Danfoss has a wakeup time. If you think now you can set a temp and this will be forced into device immediately than you think wrong. You say controller that you want 22°C and after a looooooooong time. Device is wakeup say to controller here i am and then the data will be send. That means that you must setup wakeup interval too! That is so strange. Then i start thinking why i need a window sensor?! If this don't work just in time then you don't need it really for heating purpose.
Question: Is there no way to force temp into the device?
After this knowings i started to setup Fibaro Motion Sensor. This thing is massive complex. If you understand how that works than it's fine but i have a big issue at the moment with no solution. Other way the software RaZberry is buggy to. Inclusion of this device works only in a range of 2m. The sensor itself works only in 2m. That is a thing what i don't understand at the moment. Max operation range is very very small. At the moment i don't have a solution yet. Smart Home UI will not detect the motion sensor well! You must!!! use expert UI determine which sensor this is. Via device description i can choose 4 different type of lists. That is strange. I don't know if i have the right list at the moment. All this lists are buggy! What i find out, that you can't setup the device via expert menu cause the ranges are wrong. Temp offset are between (min: 32769, max: 32767). I tested some of them. The other profiles has more bugs in it. If you want to change the value now, you have only 1 second time and the value will reset to the wrong value. Strange. This happens only via expert ui only if you go back into normal hardware configuration the wrong values will show but not refresh! If you ready you wake up the device and load all settings into it. I think, ok then i set a value to 5min for wakeup and the device will get the new informations than... Nope that doesn't work. This device will wakeup only if you triple click the b-button in it. That is so much crazy. Now i think my sensor is working, but with a extreme less range. And i don't have a clue of a faulty sensor or controller or everything...
That's my story for now. What i think is now: Buggy Software, buggy manuals, maybe buggy device and a buggy human. :roll:
