compile error
bertr
compile error
Post by bertr »
Hi there,
Bought a zuno, paured it with a zwave net work an that works fine.
Than i installed arduino IDE 1.6.5, loaded de simple blink sketch.
but when i try to compile and upload it to de Zuno, the arduino IDE gives an error:
compiler.exe: error: unrecognized arguments: pc\AppData\Roaming\Arduino15\packages\Z-Uno\hardware\zw8051\0.6.7 pc\AppData\Roaming\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.02.10/zuno_toolchain/sdcc/bin/
What do i do wrong :oops:
greetz Bert
Re: compile error
Duplicate post. This is due to a space in your user name. We will fix it in next version. Meanwhile you can make another user with single word username to workaround the problem.
